computer game question...
Discussion in 'Technology' started by OffroadToy, Jul 4, 2012.
  1. Jul 4, 2012 at 9:01 AM
    OffroadToy
    OffroadToy [OP] old, forgetful, and decomposing
    I'm an old geezer and computer challenged. I know many of you here are up on all the new tech stuff so i thought ask the experts... alot of computer games are controlled useing the up,down, and side arrows. The problem though is on alot of these games the arrows end up moving the whole page instead of controlling the game. Is there a way to keep that from happening? :confused:
  2. Jul 4, 2012 at 9:03 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Hmmm.... Computer games I play uses W,A,S,D as the directional keys instead of the arrows. Just go into the options of the game and see the controls. You can change them to your liking or see what keys do what.
  3. Jul 4, 2012 at 11:12 AM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    I use the arrow keys too :D Try running the game in fullscreen mode instead of windowed. You should be able to click in the game window to select it and this usually stops the scrolling when in windowed mode.
  4. Jul 4, 2012 at 12:58 PM
    OffroadToy
    Thanks pippen...worked great!!! :)
