2nd Gen Transmission Cooler Size & Connection
Old 04-05-2011, 04:46 PM   #1
vwmg [OP] vwmg is offline
vwmg is on a distinguished road
vwmg's Tacoma Gallery
Hi Everyone,
I was wondering if anyone could give me the dimensions of the transmission oil cooler on 2nd Generation tow package equipped Tacoma's.
Also, how is it connected?
Old 04-05-2011, 08:51 PM   #2
S.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shed
S.B.'s Avatar
S.B.'s Tacoma Gallery
Its about the size of a envelope.
Old 04-06-2011, 05:08 PM   #3
How thick is it? Do happen to have a picture? How is it connected?
Old 04-06-2011, 06:41 PM   #4
skytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shed
skytower's Avatar
Navy: Gunners Mate
skytower's Tacoma Gallery
It t's into the top line of the tranny cooler lines going to the radiator. Do not run it off the bottom line. The radiator warms as well as cools the fluid. Too cool fluid=rough shifting.
You want one with the least amount of flow resistance. Usually around 1" thick or more. It's more about efficency of cooling than size. Smaller, crossflow coolers are better than larger tube-style coolers.
Old 04-06-2011, 09:59 PM   #5
S.B.'s Avatar
Here is one photo:
Here is some more: http://s849.photobucket.com/albums/a...-Pro%20Bumper/
Old 04-07-2011, 05:53 PM   #6
Hi SB,
Is that the trans cooler that comes with the tow package, or is it an aftermarket? Also what is that trans cooler rated at in terms of towing pounds/capacity?
Old 04-07-2011, 05:56 PM   #7
Banned
The trans cooler doesn't determine towing capacity.
Old 04-07-2011, 06:43 PM   #8
S.B.'s Avatar
Originally Posted by vwmg View Post
Hi SB,
Ya it comes with the towing package. The size of cooler doesn't determine the capacity that you can tow. They say yuo can tow 6500lb with the towing package, but I seen tests where someone hooked in a trans temp gauge and with no load they were pulling some high numbers in the city.
Old 04-07-2011, 10:07 PM   #9
fvtalon is a jewel in the roughfvtalon is a jewel in the roughfvtalon is a jewel in the roughfvtalon is a jewel in the rough
fvtalon's Avatar
fvtalon's Tacoma Gallery
Hi SB,
The aftermarket ones are sometimes listed by weight. The Tacoma is rated for 5000-6500lbs for the V6 depending on equipment. I'd get the biggest most efficient cooler you can get. The tube style are the cheaper ones and don't work as good as the plate style. You can't cause any damage by having too big a cooler.
If you look at Etrailer.com they have a good selection. When I pick one up it'll be a 'class V' plate style. If you go to an AN style hookup keep in the mind the fittings are expensive and add up fast.
1rst GEN transmission cooler? bigrooster 1st Gen. Tacomas 1 06-30-2011 05:01 PM
B&M Transmission Cooler with fan/thermostat soilsample Buy / Sell / Trade 2 07-28-2010 03:43 AM
2nd gen trans cooler concern DallasPre 2nd Gen. Tacomas 16 04-24-2010 11:15 AM
Do all 2nd Gen Tacos come with a tranny cooler? r12rex 2nd Gen. Tacomas 10 08-21-2009 10:17 PM
engine oil cooler and transmission cooler linkfeeney Technical Chat 9 06-16-2008 08:08 PM
