5000 lb Boat up the Ramp?
Old 08-16-2012, 04:34 PM   #1
Florida Guy is on a distinguished road
Florida Guy's Tacoma Gallery
I am lookingfor a tow vehicle to pull a 5000 lb boat – total load including trailer, fuel,gear, etc. Until two days ago I used a 1996 F150 with a 4.9 liter in-line-6. It pulled the boat great. But it was killed by another vehicle and has gone to truck heaven. I love Toyotas (have had several – still have a Camry – and like the Tacoma over the Tundra. I’m sure with a 6500 lb tow rating the Tacoma can pull my boat on the road, but my concern is pulling up the incline of the ramp.The F150 claimed 145 hp @ 3400 rpm and 265 ft-lbs @ 2000 rpm. The Tacoma 4.0 liter V6 claims 236 hp @ 5,200 rpm and 266 ft-lb @ 4,000 rpm. At first look the torques are close, but theF150 has it on the low end where you need it when slowly coming up a ramp. The ramp I usually use is about three miles away and has excellent traction – deep grooved surface for traction– and I’ve never lost traction even with the light back end of a truck and a very wet ramp. Has anyone out there had experiences good or bad pulling a similar load up a ramp with a Tacoma? And if it will do the job, do I want to put that kind of strain on it? I don’t want to go to a Tundra, but I will if I must. Thanks in advance for your thoughts.
Old 08-16-2012, 04:40 PM   #2
the habs fan
bulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shedbulhas is one of the sharper tools in the shed
bulhas's Avatar
bulhas's Tacoma Gallery
I pull a pontoon boat all the time up some steep grades it still accelerates going up hill
Old 08-16-2012, 05:57 PM   #3
Sounds good. My boat is a fiberglass 22 ft Mako - pretty heavy rig. Do you know how much your total weight is?
Old 08-16-2012, 06:13 PM   #4
jake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shedjake72 is one of the sharper tools in the shed
jake72's Tacoma Gallery
just use 4 low.
Old 08-16-2012, 06:39 PM   #7
Kermit
SVHANC is on a distinguished road
SVHANC's Avatar
SVHANC's Tacoma Gallery
I pulled a 7000 lb wooden boat up a steep ramp with my 4cyl stick. I just put it in 4lo and let out the clutch. It idled up the ramp. No problem. No wheelspin either.
Old 08-17-2012, 05:35 AM   #8
Gregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shed
Gregman's Avatar
Gregman's Tacoma Gallery
The Tacoma has 4 low, I bet it would tow the boat up the ramp no problem even in high range 2WD.
Make sure to put a breather hose on your rear differential routed to somewhere high like your gas filler neck.
Old 08-17-2012, 05:38 PM   #9
Please excuse my ignorance, but what is 4lo? Is that only on the 4x4 Tacos, or do all the manual trannys have a 'granny' gear including the 2x4?
Old 08-17-2012, 07:09 PM   #10
asphinctersayswhat?
MJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shedMJonAgs32 is one of the sharper tools in the shed
MJonAgs32's Avatar
MJonAgs32's Tacoma Gallery
yeah 4lo is only for 4x4
Old 08-18-2012, 04:13 AM   #11
I guess I should point out that I am considering a 2 wheel drive automatic transmission Tacoma to pull with. Do you guys still think it will pull a 5000 lb boat out of a good ramp?
Old 08-18-2012, 05:07 AM   #12
the Nightman cometh!
jjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shedjjew18 is one of the sharper tools in the shed
jjew18's Avatar
jjew18's Tacoma Gallery
Yes, I have a 2wd PreRunner and my boats tow fine, it can get slippery on some ramps but overall you will be fine. I assume it is the 6 cylinder and not the 4?
Boat ramp questions.... nate1253 Towing 30 07-29-2012 07:57 PM
Pulling a 5000 lb (dry) weight, 500 lb tongue weight trailer IslandGuy Towing 6 12-24-2011 11:10 AM
Prerunner on boat ramp? R1inSC 2nd Gen. Tacomas 14 07-12-2011 01:01 PM
Tundra Boat Ramp Accident Killer Off-Topic Discussion 29 07-06-2011 07:14 PM
2wd Prerunner at the boat ramp? grant22 Towing 23 05-22-2010 11:18 AM
