3820 dry weight on HTT, now what?
Old 09-19-2012, 01:33 PM   #1
12tacoma928 is on a distinguished road
Law Enforcement:
12tacoma928's Tacoma Gallery
I have a 2012 Tacoma DBL cab with factory tow package, got a brake controller installed and the hybrid travel trailer (HTT) we just bought came with a weight distribution hitch, the HTT is a Forest River Zepplin 2006 EZ190, paperwork that came with it says 3820 lbs dry. Was able to tow is from Schenectady to Plattsburgh (2hrs) without too much concern, but it did take a full tank of gas! the camper is about 21 feet long, two axles. My questions are:
1. will that 'dry weight' include the stove/AC/microwave/fridge?
2. should I be concerned that adding propane, bedding, food, water to 45 gallon tank,etc. make the trailer too heavy? I kind of don't think so considering the 6500 lbs capacity as per the manual.
3. would the 6500 lbs include passengers in the vehicle and stuff in the bed of the truck? I kind of don't think so but want to double check.
4. what is the deal with tongue weight, is that the same as 'hitch weight' in the brochure for the camper? how concerned should i be with tongue weight?
we are new to towing and having a camper, any help on the forum will be greatly appreciated!
Old 09-19-2012, 01:44 PM   #2
Say no to Bro
kirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shed
kirkofwimbo's Avatar
kirkofwimbo's Tacoma Gallery
1. Yes
2. As long as it's not more that 2700 pounds of weight that your adding
3. No. GCWR is ~11k pounds
4. Yes tongue weight = hitch weight. Taco with towing package has 640lb tongue load capacity
Old 09-19-2012, 01:49 PM   #3
Say no to Bro
Welcome to TW btw!
Old 09-19-2012, 01:51 PM   #4
Law Enforcement:
appreciate the fast response, awesome! So if I understand everything so far, with the combined weight of 11k, the 2012 tacoma 4x4 dbl cab with tow package weight plus a fuller loaded camper needs to be under the 11k lbs. I will check on the tongue weight of the camper too.
Old 09-19-2012, 01:56 PM   #5
Banned
shemp is a splendid one to beholdshemp is a splendid one to beholdshemp is a splendid one to beholdshemp is a splendid one to beholdshemp is a splendid one to beholdshemp is a splendid one to beholdshemp is a splendid one to behold
shemp's Tacoma Gallery
You're within the specs dry, and seem to have a bunch of slack left over to load it with cargo.
Published dry weights for trailers probably aren't as accurate as you would like. The best thing for you to do with respect to the trailer dry weight, is to get it weighed. In fact, it would probably be a good idea to weight it dry AND weight it "prepped to go". This will give you a much better idea about how much your cargo weighs and an idea how much you can really load into it. Weight adds up fast when you're dealing with fluids like water and propane!
The 6500 pound trailer weight is not dependent on the truck's load (passengers, cargo), however, the tongue weight (aka "hitch weight") IS. Look at the truck's payload capacity, from that SUBTRACT the TONGUE WEIGHT to determine your remaining payload capacity (passengers, fuel, cargo). The tongue weight is not supposed to exceed 650 pounds on Tacoma. Assuming that your tongue weight is maxed out, and your truck's payload capacity is 1200 pounds, that only leaves 550 pounds for fuel, passengers, and cargo. I'm sure you can realize just how easy that would be to use up.
Tandem axle trailer tongue weight should not be less than 9% of the total trailer weight, should not exceed 15% or 650 pounds, whichever you hit first. Within these constraints, you can adjust the tongue weight by moving weight front to back in the trailer. When in doubt, its better to put too much weight on the tongue than not enough.
Yes, fuel consumption hauling something like that will be TERRIBLE. This is because you're hauling a massive air dam. The only advice I can give you on this is to SLOW DOWN. Fuel consumption increases exponentially with speed. Dropping your speed by 10 km/h could reduce your fuel consumption by 25%, or even more, depending on how fast you usually drive.
Old 09-19-2012, 01:56 PM   #6
Say no to Bro
Correct. Depending on where your going camping, I would try and leave your fresh water tank empty.
Old 09-19-2012, 03:06 PM   #7
tractng is on a distinguished road
tractng's Tacoma Gallery
I thought payload is 1430 for v6?
Old 09-19-2012, 03:22 PM   #8
Say no to Bro
That's correct for a PreRunner. 4x4 equipment eats into that and knocks it down to 1295lbs
Old 09-20-2012, 06:26 AM   #9
Banned
It doesn't matter what the truck payload really is, in each case, the vehicle owner should familiarize himself with his own specific vehicle and options.
Some prerunners have a capacity of over 3/4 ton (1500 pounds).
Old 09-20-2012, 10:31 PM   #10
sechsgang will become famous soon enough
sechsgang's Tacoma Gallery
Originally Posted by shemp View Post
The 6500 pound trailer weight is not dependent on the truck's load (passengers, cargo), ....
That's not true, as with 6,500 lbs behind you, you'll go really quickly over the GCWR of 11K lbs if you load up the truck. A double cab 4x4 weighs around 4,200 lbs empty. 4,200+6,500 = 10,700lbs. That really just leaves room for a 150 - 200lbs driver and nothing else once you consider small stuff here and there that everybody normally adds.
But I agree with you that for the OP, the payload / GVWR will most likely be the limiting factor.
Old 09-20-2012, 10:53 PM   #11
Rich91710's Avatar
Rich91710's Tacoma Gallery
But I agree with you that for the OP, the payload / GCVWR will most likely be the limiting factor.
+1 with a small fix.
While the towing rating is 6400/6500, the first response nailed it with the "additional" 2700lbs...
Depending on the model of Tacoma, you may exceed GCVWR with less than 5900lbs in tow.
As mentioned, best way to be sure is to pull the rig onto a scale and weigh it road-ready.
Water adds a lot of weight... 45 gallons water tank is over 350 pounds, and it is normally ahead of the axle.
Most people I know travel empty and fill the tank at the campground or the nearest place to the campground where potable water is available.
Old 09-21-2012, 01:13 AM   #12
Badger of Death
DoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shed
DoorDing's Avatar
DoorDing's Tacoma Gallery
Also, try not to tow with a partially filled tank, especially one that large. A full tank will add a lot of weight, but a partial tank will add a lot of moving weight. I can get away with that with the little tank in my pop-up (I still drain it), but 30 gallons sloshing around in yours might be ... exciting.
Old 09-21-2012, 09:52 AM   #13
Banned
Go back and read the question I was responding to, and then re-read my answer to it.
Old 09-21-2012, 10:19 AM   #14
People should remember tongue weight is part of payload allowance.
Old 09-21-2012, 06:38 PM   #15
Rich91710's Avatar
Your answer is still incorrect, because the GCVWR will be exceeded with a 6500lb trailer and a truck loaded to it's GVWR.
You can easily bump into the GCVWR with the trailer as low as 5600.
Old 09-21-2012, 10:47 PM   #16
Maybe we have a different interpretation of the question and answer, but I still think what you said is incorrect, sorry.
Old 09-24-2012, 06:26 AM   #17
Banned
The question was:
The answer is NO, the truck's payload capacity is independent of the trailer's total weight. Only the TONGUE weight would impact the vehicle's payload.
I.e., VEHICLE LOAD = passengers + cargo + fuel + tongue weight.
What he is asking is very simple: he wants to know if he should observe the following relation:
passengers + cargo + fuel + trailerGVW < 6500.
No.
He needs to observe this;
(passengers + cargo + fuel + tongue weight < truckPayloadCap AND trailerTotalWeight < truckTrailerCap).
More clear?
How do you dry your truck? Lentsnh Detailing 614 10-19-2014 04:17 PM
Poll: Stock intake with AFE Pro-Dry S Filter or AFE Stage 2 Intake with Pro-Dry S fkli222 Performance and Tuning 34 11-27-2013 12:15 AM
Do I need a break controller on 3375 Dry weight with 390 lbs Tongue weight JUJtacoma2010 Towing 13 06-25-2012 06:28 AM
Pulling a 5000 lb (dry) weight, 500 lb tongue weight trailer IslandGuy Towing 6 12-24-2011 12:10 PM
AEM DRY greatfuldead 2nd Gen. Tacomas 4 11-25-2010 11:39 PM
