7 pin help
Old 04-14-2013, 03:06 PM   #1
empty hull [OP] empty hull is offline
empty hull is on a distinguished road
empty hull's Tacoma Gallery
7 pin help
I just bought a boat and will pick it up next Saturday. The trailer is having surge brakes installed and the salesman stated it will use a 5pin flat connector. When I got back from Florida, I looked into my glove box and noticed that I only have the 7-pin to 4-pin adapter #PT791-89040. Do they make a 5-pin model that will fit. Truck is a 2009 Tacoma TRD Offroad 2wwd. Thanks, Tim
Old 04-14-2013, 03:12 PM   #2
Glamour Shot
ajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shed
ajohnson's Avatar
ajohnson's Tacoma Gallery
Can the boat dealer not sell you a 7 to 5 pin adapter? You can find one at a bunch of stores, even Home Depot.
Old 04-14-2013, 03:19 PM   #3
Didn't realize that it was a 7 to 4 pin adapter until I got back to Louisiana. I have read that some connectors do not work/fit the Toyota. I do see one #51-30703 and #85212 from Auto Zone but not sure these will fit. Just trying to eliminate a problem before I go back and pick this boat up in Florida and head back home. Tim
Old 04-14-2013, 03:24 PM   #4
Glamour Shot
ajohnson's Avatar
I was thinking you could ask them to have one when you pick the boat up. I have not heard about adapters not working on a Tacoma. I have bought 2 from different stores and not had a problem. But if you go to a place like Auto Zone or whatever, ask if you can make sure it fits before you drive home with it.
Old 04-14-2013, 03:30 PM   #5
That is a good idea. I wonder if the can just wire straight to a 7 pin and be done with it? Tim
Old 04-14-2013, 03:33 PM   #6
2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed
2000GTacoma's Avatar
2000GTacoma's Tacoma Gallery
You could put a 7 pin connector on the boat. Just have a couple empty pins but it would work.
Old 04-14-2013, 03:34 PM   #7
Glamour Shot
ajohnson's Avatar
Either way. I personally would go with 2000GT's suggestion, wire a 7 pin to the boat. That way you can have the 7 pin on your truck if you ever need it.
Old 04-14-2013, 03:38 PM   #8
GO VOLS!
TnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shedTnRedNeck721 is one of the sharper tools in the shed
TnRedNeck721's Avatar
TnRedNeck721's Tacoma Gallery
wal mart has 7 pin to 4flat and 5flat. it has both 4 and 5 flat. i have one.
Old 04-14-2013, 07:31 PM   #9
Thanks guys for all the info. I do not think I should have a problem next weekend. Tim
FS: 7 pin to 4 pin bungee adapter gov875 2nd Gen Tacoma Marketplace 6 01-05-2013 01:51 PM
Switching 7 pin to a 4 pin txduckhunter Towing 7 01-18-2012 08:44 PM
7 pin to 4 pin harness/adapter TacoDawgs 2nd Gen. Tacomas 17 12-30-2011 09:21 PM
4 pin to 7 pin conversion and BC - 2G non-tow pckg fvtalon Towing 14 04-20-2011 07:59 PM
7-pin to 4-pin converter JMark Towing 8 06-13-2010 06:51 PM
