Towing long distance
Old 01-19-2014, 09:12 PM   #1
robm7 [OP] robm7 is offline
robm7 is on a distinguished road
robm7's Avatar
robm7's Tacoma Gallery
Hi folks,
In a few months I will be driving from Alaska to Missouri. Yes this is going to be one heck of a road trip. I will be towing my camplite 13QBB travel trailer too. I probably will get the oil changed in the spring but what else can I do to prepare my Rig for the journey and not kill it?
My Rig is a '12 DBSB V6; picks for clicks:
Old 01-19-2014, 09:13 PM   #2
robm7's Avatar
BTW, it does have trailer brakes and timbrens in addition to the factory towing package.
Old 01-19-2014, 09:19 PM   #3
I'm lost
1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed1993t100 is one of the sharper tools in the shed
1993t100's Avatar
1993t100's Tacoma Gallery
I don't really think there's really a whole lot you can do, but I'm also not a towing expert haha.
That camper doesn't look to be that heavy, I think the truck will make it just fine! Have a safe trip!
Old 01-19-2014, 09:22 PM   #4
robm7's Avatar
Here are some specs I grabbed from their website:
Box Length 13'-0" Dry Weight *2,350 lbs
Overall Length: 16'-6" Load Capacity: *650 lbs.
Overall Width: 7'-0" Hitch Weight: 170 lbs.
Height w/AC: 9'-6" Grey Water: 27 gal.
Tire Size: 13" Black Water: 14 gal.
GVWR: 3,000 lbs. Fresh Water: 20 gal.
Old 01-19-2014, 09:31 PM   #5
robm7's Avatar
I have learned to become self-sufficient when traveling. I've had too many dead camper batteries die when I was thought I was GTG. So here is a list of what I I will bring:
- honda 2k generator
- battery voltage reader
- battery charger and engine starter
- fuel
- tow straps
- extra rubber gloves for the water dumping station
Just to name a few things. I am debating whether or not I should bring an extra mounted and balanced tire.
Old 01-19-2014, 09:34 PM   #6
Lord of War
KenLyns's Avatar
KenLyns's Tacoma Gallery
Changing the rear diff gear old to synthetic 75W90 (or even better, 75W140) would be about the only thing I'd recommend. At 3000 lb gross, the trailer isn't heavy. Make sure the trailer tires are in good condition and at the right pressure.
Old 01-19-2014, 09:43 PM   #7
I'm lost
1993t100's Avatar
- fuel
- tow straps
No doubt if you can, bring an extra trailer tire and obviously an extra truck tire. Always good to have those!
Old 01-19-2014, 09:52 PM   #8
phiniac is on a distinguished road
phiniac's Tacoma Gallery
camper looks pretty light so weight shouldn't be much of an issue.
A couple of common sense things:
1. Towing mirrors (didn't see any in the pic)
2. fix a flat (couple of cans)
3. tire plugs
4. 12v air compressor
5. extra cans of gas (expect 10 or so mpg)
6. check all your fluids (brake fluid, coolant etc...)
7. tools for roadside fixes, including jacks and lug wrench
8. Duct tape (never leave home without it)
drive safe and enjoy the views!
Old 01-19-2014, 09:57 PM   #9
robm7's Avatar
Yes tools are a must! An extra trailer wheel would be good too. I have been towing this TT for the last two summers and after adjusting the mirrors to view the dead space I don't think I need towing mirrors.
The back up camera on the Taco has been a God-send; I know I would have more dents in the back of my truck without it. I am getting better at parking a single-axle trailer tho :-p
Old 01-19-2014, 10:00 PM   #10
Some states require by law extended mirrors when towing.
Old 01-20-2014, 08:04 AM   #11
Master Baiter
jethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shedjethro is one of the sharper tools in the shed
jethro's Avatar
jethro's Tacoma Gallery
In NH you can get pulled over if you do not have extended mirrors. Even with a camera, they will pull you over because they can't see that you have one. Last time it happened to me, the cop said he does the same thing for every stop... gets about 7 car lengths behind you and if he can't see the reflection of his lights in your side mirrors- the blue lights go on.
I use the cheap strap on mirrors more for compliance than anything.
Old 01-20-2014, 09:28 AM   #12
robm7's Avatar
I'm checking out the K Source mirrors from etrailer. Does anyone own these? They look pretty sturdy and inexpensive.
Old 01-20-2014, 07:19 PM   #13
robm7's Avatar
How good is this stuff?
Old 01-20-2014, 08:28 PM   #14
Lord of War
KenLyns's Avatar
^Very good. The trailer isn't heavy, but you are pulling it for a long distance, so the rear diff would be running hotter than without a trailer. Synthetic gear oil doesn't degrade as easily as conventional oil when hot.
Old 01-20-2014, 09:49 PM   #15
robm7's Avatar
Thanks for the tip. I will be sure to get that done. Does Toyota have a synthetic LSD oil? Or do you recommend a particular brand?
Old 01-20-2014, 09:50 PM   #16
robm7's Avatar
Correction; not LSD but rear diff fluid.
Old 01-20-2014, 10:06 PM   #17
Lord of War
KenLyns's Avatar
Toyota doesn't have a synthetic gear oil, at least when i checked at my dealer. Use whatever famous brand synthetic GL5 75W90 or 75W140 that's on sale. Castrol, Lucas, Mobil 1, Quaker State, whatever.
Old 02-08-2014, 06:56 PM   #18
52motorhead is on a distinguished road
52motorhead's Avatar
52motorhead's Tacoma Gallery
Make sure your wheel bearings on the trailer are good and greased and check tire pressures .
Old 02-09-2014, 09:22 AM   #19
robm7's Avatar
Had them re packed last summer. Winter has lowered the tire pressure tho
Old 02-09-2014, 09:47 AM   #20
Old & Forgetful
Janster's Avatar
Gender: Female
Janster's Tacoma Gallery
As others have already mentioned.....make sure you have a spare trailer tire that's in good shape. Make sure the spare is not old and dry rotted, has plenty of tread left, and can hold air.
Make sure all your suspension components on the trailer are tight and in good working order..... Trailer brakes, bearings, seals, are good.
I've been on a couple long distance trips with groups of people...and have seen some ugly issues on the highway that was LUCKY nobody got hurt. From locked up trailer brakes that created so much heat that destroyed the bearings and the entire wheel came off. To..... rusted frame/suspension components that broke while doing 65mph down the highway.
Crawl under your trailer and inspect everything!! Make sure your trailer brakes work... Even though the bearings were packed last year - I would still remove the tires and inspect the internals, brakes, bearings, seals.
I wish you luck for a safe & 'trouble free' trip!!!
Bad idea to tow long distance with 2.7? SpeedoJosh 1st Gen. Tacomas 7 08-09-2013 12:00 PM
Tacoma for long distance commutes nullsignature 2nd Gen. Tacomas 46 06-03-2013 02:58 PM
Ultragauge- long distance ekapec 2nd Gen. Tacomas 1 06-06-2012 01:19 PM
lets see your long distance rifles muleyhunter Guns & Hunting 20 01-29-2012 05:26 PM
long distance towing DSMissed Towing 17 05-06-2011 08:16 PM
