Towing and wheel spacers - any issues?
Discussion in 'Towing' started by KDOG, Feb 4, 2014.
  1. Feb 4, 2014 at 2:39 PM
    KDOG
    KDOG [OP] Well-Known Member
    Belleplain, NJ
    Bilsteins, OME 884s, 3 stage progressive AALs.
    Thinking of adding wheel spacers (like the Spidertrax 1.25s) when I do my wheel/tire upgrade but I tow a 3500lb camper (dry weight). I have a WD hitch. Are there any known issues with slavers and towing?
  2. Jun 16, 2014 at 2:09 PM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    old thread but I have those spacers and a camper pretty close to the same weight. I haven't towed it very much since I got the spacers though, I was kind of wondering the same thing really. I talked to spidertrax and they reassured that the forces from off roading are greater than when towing. The spacers are billet aluminum which is stronger than cast which are what our wheels are made out of. they basically told me the wheels are the weak point...
  3. Jun 16, 2014 at 2:16 PM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    I've got spidertrax and do quite a bit of towing, no issues for me so far!
  4. Jun 16, 2014 at 2:22 PM
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    I wouldnt man. Another dude on here had a wheel break off due to spidertrax. I wouldn't wanna be towing something heavy and wake up dead the next morning because my wheels fell off with almost 2 tons dragging behind me on fully functional wheels lol
  5. Jun 16, 2014 at 2:23 PM
    BillJC
    BillJC Well-Known Member
    Bill
    Novato, CA
    2011 White SR5 DCLB 4x4
    Pretty much what wake100 said. The wheels will break before the spacers. I have 1.25 spidertrax spacers and tow with no issues.
  6. Jun 16, 2014 at 2:28 PM
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    that's genius right there :rolleyes:
    OP, there is nothing wrong with towing to the full capacity of your truck with properly installed wheel spacers. 3500 lbs will definitely not be a problem. However why are you considering spacers in the first place? Need the clearance or just like the look?
  7. Jun 16, 2014 at 2:37 PM
    GEORGE STRAIT
    Da Magic City, AL
    Sarcasm.. Just tryin to save lives. Wouldn't want my kids to get killed by a stray airborne tire either
  8. Jun 16, 2014 at 2:55 PM
    BillJC
    Bill
    Novato, CA
    Who's wheel broke off due to a spidertrax?
  9. Jun 16, 2014 at 2:59 PM
    GEORGE STRAIT
    Da Magic City, AL
    I'll try to find the link. I saw some pictures on here the other day of a guy who it happened too. Theres also this guy, who had no pics:
  10. Jun 16, 2014 at 3:06 PM
    GEORGE STRAIT
    Da Magic City, AL
    Spacer studs sheared off when he was going down the interstate.
  11. Jun 16, 2014 at 3:14 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    because they were over torqued , says so right in the post you linked , same thing can happen to the regular wheel studs
  12. Jun 16, 2014 at 3:16 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    Due to improper torque most likely. If they are not properly installed they can snap off just like if you install your wheels with improper torque. There is noting wrong with properly installed wheel spacers and SpiderTrax are one of the best on the market.
    Edit peter beat me to it.
  13. Jun 16, 2014 at 5:34 PM
    GEORGE STRAIT
    Da Magic City, AL
    Doesn't matter. He said it was done at a toyota dealership, so you never know when they are at risk for failure.
  14. Jun 16, 2014 at 5:42 PM
    JLee
    Jerry
    Benicia, CA
    The same can be said for your wheels that has nothing to do with spacers. Lugs are lugs and if they are over torqued they can fail.
  15. Jun 16, 2014 at 5:48 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    I have Bora .75" spacers on the front only to keep my '09 TRD wheel-265/75/16's off my upper A's.....
    Towed a loaded 5x8 U-Haul trailer 1500 plus miles from NH to Florida without a single problem .....
    TORQUE TORQUE TORQUE.......You read all these horror tales and what is the "constant".......;) :cool:
  16. Jun 16, 2014 at 5:50 PM
    GEORGE STRAIT
    Da Magic City, AL
    I'm not buying the assertion that wheels are just as likely to break off while in motion as a wheel spacer
  17. Jun 16, 2014 at 6:04 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Same thing happened to me. There were no spacers in the rear, just over torqued and fatigued from the many many many times I have my wheels on and off..
    I do however have spacers in the front along with my long travel kit and tow frequently without any issues..
  18. Jun 16, 2014 at 6:05 PM
    snoope
    Then READ on about seperation for under and over torqued wheels; both on pick-ups and large tractor trailers.....Steel and aluminum wheels and their "ends" can become missiles...
    You over or under TORQUE anything and chaos can ensue...
    And I will be "Devils advocate" for tires also.....Since I drive for a living the number or Virgin tires going "POP" is equal to caps....
    PROPER WHEEL & TIRE maintainence is CRITICAL......You think a 1/2 ton pick-up with a trailer is a "b!tch" when it goes wrong.
    Try it at 80000 lbs of "OOPS"
  19. Jun 16, 2014 at 6:24 PM
    JLee
    Jerry
    Benicia, CA
    Well they are buy it or not.
  20. Jun 16, 2014 at 6:27 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    He doesn't read, no need to. He knows all there is to know on any subject, the end all be all.
