Should the aux. tranny cooler be hot?
Discussion in 'Towing' started by Sterdog, Jun 3, 2014.
  1. Jun 4, 2014 at 7:06 PM
    #21
    BamaToy1997
    Bill
    Navarre, FL
    Add-on coolers are not difficult to install. The question remains WHERE to install it. You don't want to block too much of the condenser, or radiator because both need the cooler air passing over them to do THEIR job. If you already have an additional cooler you SHOULD be ok for normal towing and such. The key of course, as mentioned, is finding out what your ACTUAL temp is. Until then I wouldn't do anything.
  2. Jun 4, 2014 at 7:56 PM
    #22
    Sterdog
    Sterdog [OP] Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Agreed! It sucks that the diagnostic costs more than the fix though. Oh well, hopefully I can Kijiji off the Edge Insight for close to what I paid for it then I'll have lots of extra cash to pay off the ScanGauge.
  3. Jun 5, 2014 at 9:34 PM
    #23
    drifter379
    drifter379 CenTex Honky
    Texas
    06 Tacoma SR5 Prerunner
    Secondary Air filter mod,Removed running boards,AFE Pro dry filter,sirius satelite radio,relocated horns,sockmonkey decal,EZ change drain plug,color matched grille,grille craft mx, BHLM, Fog light mod, Hellas behind the grille
    Great info. I've been considering a trans cooler for a while.
  4. Jun 6, 2014 at 12:38 PM
    #24
    Sterdog
    I am Groot
    15 FoST
    Okay, so luck has it that the cooler came in this afternoon. I quickly installed it with a blend mount and now I have to run back to work. I will post my TFT temps tomorrow once I get back. BTW this ScanGauge is sweet! I even have it spitting out my A/F ratio which is a huge deal since I'm supercharged and looking at pushing my tune in several years once the warranty is up! My only complaint is that is it has a ghetto display when compared to pretty much everything else out there... simple yet effective was there moto I guess.
  5. Jun 7, 2014 at 5:50 PM
    #25
    Sterdog
    I am Groot
    15 FoST
    Looks like I had a false alarm. After towing for ~60 miles the scangauge never showed a temperature over 220, and 95 percent of the time the temp was under 200. I guess there's no logical reason to upgrade to a bigger aux transmission cooler for now.
  6. Jun 7, 2014 at 6:00 PM
    #26
    SpoilsofWar
    SpoilsofWar Well-Known Member
    Jason
    Wilmington NC
    2014 DCLB 4x4 TRD Sport Super Charged
    Where did you find the code for the afr?
  7. Jun 8, 2014 at 8:59 PM
    #27
    Sterdog
    I am Groot
    15 FoST
    I didn't find it, vicali did the leg work on that for me and passed it along. Nice guy, positive rep added :eek:. Most of the codes can be found on the X-gauge site or various others. He lists a lot of them here:
    http://www.ct4wd.com/forum/showthread.php?6463-Vicali-2005-Build&p=98182
    If you can't see them, here is the one for A/F:
    Air Fuel Ratio (should be ~14.7);
    TXD:07DF0124
    RXF:044145240000
    RXD:2808
    MTH:05B900800000
    I'm not sure how super accurate it is, but it's better than nothing at all.
  8. Jul 24, 2014 at 9:11 AM
    #28
    shr133
    shr133 Well-Known Member
    Steve
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    if you are going to tow a lot you should get a trans cooler to keep the temps below 220, with out an additional cooler temps can get over 250..
  9. Jul 24, 2014 at 11:54 AM
    #29
    liveload
    liveload Active Member
    Colorado Springs
    07 Tundra 5.7L 4x4 Dbl Cab
    Hello gearcruncher, I have an 06 TRD V6 with an automatic. Is there a how-to guide or write-up for installing that cooler on that series of Tacoma? I am thinking about getting one soon but am a bit intimidated by the thought of hacking the tranny.
  10. Jul 24, 2014 at 7:21 PM
    #30
    gearcruncher
    gearcruncher Well-Known Member
    Canadain bumper technician
    Great white North 51.0333° N, 93.8333° W
    2010.TRD.SportDCLB4x4Limited leather package
    TRD Sport Rally -5 speed automatic Limited ,Factory heated leather seats ,chrome package,Super white with front windows tinted to 35 % Dick Cepek DC-2 wheels Summer tires - Good year silent armor P265/65R17 Winter tires - Good year P265/65R17 Ultra Ice studded Illuminated 4x4 switch TRD 3rd brake light cover ($20) TRD seat belt shoulder protectors (5). ($50) TRD ...B pillar emblems ($20) TRD rear slider sticker with devil horns ( $6) TRD summer floor matts ($60) TRD steering wheel emblem ($20) TRD floor pedals .($95) TRD shorty antenna ($14) TRD front Windshield emblems ($17) TRD head pillows .($60) TRD head rest protectors TRD door scuff protection $20 TRD floor matt emblems ($40) TRD tow plug emblem . ($40) TRD cigarette lighter with LED.($35) TRD tissue dispenser ($12) TRD front bezel emblems ($9) TRD door emblems ($6) TRD lanyards($9) TRD lisence plates with TRD bolts($50) TRD fender emblems TRD center caps Part Number:PT904-35070-CC ($80) TRD cd
  11. Jul 25, 2014 at 9:28 AM
    #31
    liveload
    Colorado Springs
    Thanks GC!
    Question: I wonder if the Gen 2 is any different in procedure from the Gen 1 in the linked writeup. The guys at the local 4Wheel Parts advised that my transmission fluid is pressurized and recommended I have Toyota change the fluid (~$180 procedure). In the write-up there was a spray of fluid all over the place when he cut into the lines. I'd like to avoid cutting into pressurized lines if it can at all be helped. I just envision bad things happening when Idiot A (me) cuts into Pressurized Transmission Component B.
  12. Jul 25, 2014 at 9:41 AM
    #32
    Sterdog
    I am Groot
    15 FoST
    Read the rest of the thread. With a scangauge I can read the pan and converter temperature on my Tacoma as I tow. Right now even on heavy grades I'm not seeing tranny temps above 220 except for a split second, so I won't be upgrading anything since the stock system is working so well. If I change my fluid every 40K like I plan I will be fine.
    Right now the wife and I are looking at getting a full sized for her to take over towing duties anyways :D.
