Discussion in 'Towing' started by Tacos Dorados, Jun 8, 2014.
  1. Jun 8, 2014 at 12:53 PM
    Tacos Dorados
    Tacos Dorados [OP] Member
    Ojai California
  2. Jun 8, 2014 at 12:53 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  3. Jun 8, 2014 at 12:56 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I tow with mine. The biggest issue you will have is needing to drop your ball a lot. I had a 7.5" drop on mine and it wasn't nearly enough, but it worked. I could swing open my swingout just fine with the trailer I had.
  4. Jun 8, 2014 at 1:03 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    same here - 12" drop hitch for mine.
    swing out is unaffected
  5. Jun 8, 2014 at 1:21 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    wow - that's a classic. :cool:
  6. Jun 8, 2014 at 1:22 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    What's the dimension from bumper to propane tank?
  7. Jun 8, 2014 at 1:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I do with mine. 8'' drop hitch. Still big high..
  8. Jun 8, 2014 at 1:34 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    My swingout would not clear even close to 30". I think you will clear the jack handle though. You may need to go with one of the dual swingout setups. I would almost suggest a hitch extension tube, but it already looks like you are nose high and it would make that worse.
  9. Jun 8, 2014 at 3:48 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Never heard of it. My frame hasn't bent yet. It's brand new though.
  10. Jun 10, 2014 at 12:20 AM
    NoSilverBullet
    NoSilverBullet N60 member
    Northern Canada
    2012 AC 2.7 MT 4wd
    Old Man Emu suspension: 884x coils, Dakar leaf pack, Nitrocharger Sport shocks. Cruisin Offroad bolt-on sliders. Relentless Fabrication aluminum front and mid skid plates + steel transfer case skid. SnugTop Hi-Liner "Sportsman" canopy. Hella Rallye 4000i Xenon (flood beam).
    That camping trailer looks really good!
  11. Jun 10, 2014 at 12:26 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Not to offend you, but the most likely cause for a bent frame would towing over the capacity, or a wreck.
  12. Jun 10, 2014 at 12:47 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    My issues are cant boat trailer( boat off) with the tire in the way and cant open swing out.
  13. Jun 10, 2014 at 1:51 AM
    ffdawson
    ffdawson Dirt Head
    Penngrove
    08 Tacoma Rugged Trail 6spd
    Kings, Armor, big taaaarrrs
    So I tow with mine, it's not a high clearance, but my swing out DOES hit the trailer. My solution is to turn sharply as I park, and with enough angle I can swing the arm out freely. It was kind of a PITA originally but now I'm used to it and it's really not much of an issue.
    Dual swing outs would be ideal.
    In this pic you can see, I don't have to turn much, just slightly. It's not like I have to jackknife it or anything...
  14. Jun 10, 2014 at 7:04 AM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    Yes sir. Unless I jackknife it. If I was to do it again I wouldnt get the swing out. Too many other cons. Like putting long stuff in bed, sometimes the swingout opens while driving workin on a fix for that.
  15. Jun 10, 2014 at 8:40 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    My swingout has never opened while driving. It's my biggest fear though. A swingout is pretty inconvenient, but overly badass.
  16. Jun 10, 2014 at 9:04 AM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    Yeah I really like the looks of it. Pretty scary when you see it in the sideview mirror.
