Tow Ball - quality question
Old 09-04-2014, 07:14 PM   #1
20fourteen [OP] 20fourteen is offline
20fourteen is a name known to all20fourteen is a name known to all20fourteen is a name known to all20fourteen is a name known to all20fourteen is a name known to all20fourteen is a name known to all
20fourteen's Tacoma Gallery
I need to get a tow ball, and was wondering if there are quality differences or if some brands are better than others? Don't want to spend extra if not needed, but don't want to have something that is going to fall apart or shear due to cheap quality steel.
Old 09-05-2014, 08:12 AM   #2
fuzzai is on a distinguished road
fuzzai's Tacoma Gallery
I can't answer on quality or what not.
But i was in a recent store looking for a 2" ball, normally i stick with Reese.
They had a 2" 6000 lbs towing for 35$, or a 2" 7500 lbs for 15$. It was a darker colored ball, i don't remember the type of steel it was thoe...
Old 09-05-2014, 08:21 AM   #3
Ditch Doctor
medic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shedmedic2230 is one of the sharper tools in the shed
medic2230's Avatar
EMS:
medic2230's Tacoma Gallery
Keep in mind also to buy the correct size shaft for the tow bar you are using too. I've always used Reese brand and never had a problem.
Old 09-05-2014, 08:22 AM   #4
Sandyman is on a distinguished road
Air Force: (8) USAF, (29+) Civil Service
Sandyman's Tacoma Gallery
Watch out for the universal fit ball that has a spacer to fill the mounting hole. I had one years ago that would work loose because the spacer was actually longer than the bumper thickness and I almost lost a trailer with two motorcycles.
Sandy
(Like 5 seconds late)
Old 09-07-2014, 07:15 PM   #5
ToyotaLover
Smar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shedSmar969905 is one of the sharper tools in the shed
Smar969905's Avatar
Smar969905's Tacoma Gallery
I have seen a 2" ball rated as high as 8000#. Typically a 2" ball is 5000-6000# rated. The trick is knowing how much drop/rise you need, ball size, and loaded trailer weight. My horse trailer is 2600# empty and made for 2 horses. I figure with my 2 horses in it, as well as tack, and anything else we need, it would be about 5500# to pull. It also rides on a 2" ball. Much more and it would be going for a 2-5/16" ball that is usually about 12-15k rated.
If you look at a section of drop hitches and varying sized balls, you can see that the different balls come with varying sized shafts, which change weight rating. A weight rating on multiple parts is only as high as the lowest part. It is usually cheaper to get a kit (drop hitch, ball, and lock pin) than to buy the parts individually.
A 6000# drop hitch that is cheaper should do the same for you as a 5000# hitch that is more expensive.
needing good quality ball joints and steering rack lshouse35 2nd Gen. Tacomas 4 06-28-2014 06:52 AM
Tow ball gets scratched mr2mki Towing 60 02-28-2014 09:43 PM
MOOG quality and some other info on Ball joints Peru Suspension 16 10-26-2013 07:13 PM
Tow Hitch Ball persian451 1st Gen. Tacomas 11 11-01-2012 03:40 PM
Great Deal on Quality Tow Strap trdNick Deals & Coupons 4 02-18-2012 11:37 AM
