Tow Hitch Rattle
Discussion in 'Towing' started by rkarabao, Oct 22, 2014.
  1. Oct 22, 2014 at 3:41 AM
    rkarabao
    rkarabao [OP] Well-Known Member
    2013 TRD Tacoma
    Okay... so I like to run with my receiver hitches mounted due to frequency of use and the tailgating deterrent factor!
    My problem is that I noticed surface rust so I hit it with some anti-rust lubricant and now its so loose the rattling is driving me nuts. I was thinking of lining the hitch shaft with either a plastic or rubber liner (insert condom joke here!) to stop the rattling but don't want to run into problems when I need to swap out hitches or transfer it to my other vehicles.
    Has anyone here solved this problem with a simple solution?
  2. Oct 22, 2014 at 4:02 AM
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
  3. Oct 23, 2014 at 4:27 AM
    rkarabao
    2013 TRD Tacoma
  4. Oct 23, 2014 at 5:08 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I just wrap mine with electrical tape. No more rattle.
  5. Oct 23, 2014 at 6:06 AM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    I sprayed mine with rubberized coating.
  6. Oct 23, 2014 at 6:21 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I take mine out I don't like bruised shins.
  7. Oct 23, 2014 at 6:35 AM
    ERMB
    2002 Land Cruiser
    Lol, that also takes care of the rattle problem:D
  8. Oct 23, 2014 at 7:11 AM
    lowcountrytj
    lowcountrytj Third Member
    Phillip
    Probably at Work
    2012 DCLB TRD SPORT "BLACKOUT"
    If you have a welder or know of anyone who has one you can put a few spot welds in different locations on the shaft. May have to knock them down with grinder for proper fit.
    I ran a couple beads length wise on mine.
  9. Oct 23, 2014 at 6:02 PM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    Only works if you have a hollow ball mount.
    A high grade Bolt, washer and nut will work too. Put some locktight on the threads and drill a hole in the end of the bolt for cotter pin. The finer the thread bolt you have the tighter you will get it. Crank it down as tight as you can get it. Who's going to be walking around with a 1" or 1 1/8" wrench to get it off.
    I have also used a metal can to take up the slack.
