thinking about buying this travel trailer?
Discussion in 'Towing' started by TMS2334, Jan 28, 2015.
  1. Jan 28, 2015 at 1:00 PM
    TMS2334
    TMS2334 [OP] Member
    2014 TRD OFF ROAD silver sky metalic
    Bilstien 5100 set 2.5,toytec add a leaf 1.5, 285-70x17 method double standard, window tint,wet okole seat covers, husky weather beaters, camper shell.
  2. Jan 28, 2015 at 1:58 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Steve
    Buffalo NY
    2010 RC 2.7 4x4
    BUCKLE UP! It makes it harder for Aliens to pull you out of your Truck.
    I like the shitter at the rear.
  3. Jan 28, 2015 at 2:17 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Neither one if you don't have the factory towing package. With the factory towing, make sure it has trailer brakes. It will still be a hand full. Rear shitter FTW!:thumbsup:
    Welcome to TW!:wave:
  4. Jan 28, 2015 at 2:22 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    I don't see trailer brakes listed on the list of trailer features. Considering some of the stuff they're listing - that's noticable by its absence. Make sure it has brakes!
    Aside from that - err on the side of the smallest trailer that meets your needs. Everyone always overloads their trailers.
  5. Jan 28, 2015 at 2:45 PM
    TMS2334
    TMS2334 [OP] Member
    My truck does have the factory tow package and both trailers do have brakes in california anything over 2000 has to have brakes installed. But as far as the weights and length. It seams smaller than what I've seen guys towing on here.
  6. Jan 28, 2015 at 2:56 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Either should be fine. Get a Equalizer hitch or similar. Pull it in 4th (not Drive/5th). I like the Prodigy 3 brake controller. It's a little more but worth it. There's a thread w/ replacement mirrors for towing somewhere her on this forum. Those might be helpful as well.
  7. Jan 28, 2015 at 6:23 PM
    robssol
    Rob
    S. Wisconsin
    ProEFX heated towing mirrors FTW
  8. Jan 28, 2015 at 6:49 PM
    TMS2334
    TMS2334 [OP] Member
    Those are pretty sweet mirrors I will have to find the thread on those. So you are thinking these trailers will be safe to tow with not to much trouble for the truck
  9. Jan 28, 2015 at 7:49 PM
    Jefes Taco
    Denver, CO
    Those are the ones.
    Should be fine. They are 3000 and 3300 unloaded w/ a max of 5500 loaded. Your Tacoma should be rated right at 6400. 6400 - 20% = 5120. Close enough for me. Don't overload it. Little to no water unless you really need to take it. That'll save 250+ lbs. right off. It's not going to pull like a diesel but it should be capable and safe. It's not a race when pulling an RV. If you decide you need a bigger truck the Tacoma demands top dollar on the open market. Could be worse. :D
  10. Jan 30, 2015 at 6:03 AM
    oldstick
    oldstick Medicare Member
    GA
    Are they one axle or two? Say's "3500 lb. axle" but gross weight up to 5500?
  11. Jan 30, 2015 at 6:46 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    Thanks guys
    Click on link in sig
  12. Jan 30, 2015 at 10:18 AM
    TMS2334
    TMS2334 [OP] Member
    Yes they are both dual axles.
