Products Referenced | Thread Tools | Search this Thread | Display Modes |
#261 |
Brake Controller Install for a 4x4 Reg Cab
Hi all,
I am in the market for a boat that comes with brakes on it. However, due to Toyota's short thinking, I don't have a brake controller plug in my truck via the factory harness as it is the 4x4 reg cab 4 cylinder 5 spd. manual tranny. I have installed a Valley-T class III hitch and got the Valley-T 4 pole harness adaptor and then installed the 4 to 7 pole (with 4 pole on it) adaptor as well. My question is whether or not I can install a brake controller on this truck. I looked in my fuse box under the hood and there is a spot for the 30 Amp relay that is open...... I am an electro/mechanical tech....so my knowledge is good, but the Towing Bible did't cover my needs. I am no pro at towing by any means, so I ask the guru.....please....teach me..... |
#262 | |
I have TWO thumbs..... ;)
I would even hazard a guess and say you can't/shouldn't tow anything heavy enough to require brakes with the 4 banger. Someone correct me if I'm wrong, but I don't think a 4 banger, non-tow package can tow enough to worry about brakes.
__________________
![]() Like when daddy plays with mommy on her "woman week", I've caught you red handed. Cheap/free mods - Tacoma World Forums |
#263 |
Towing with the 4-bangah!
Well, it is a boat that is about 17 feet long. The trailers are noted to have brakes on them. The boat is about 2k and the trailer another 300# so I am well under the weight limit...though a full tank of gas on the boat adds another 200#. It was 'suggested' that if the trailer has brakes, to use them.
Also, the wires would have to be run from the cab / controller to the adapter, but the adaptor has the blue, black and other necessary leads. I have read that the 4 banger has done well with towing as long as you stay under 3k#. |
#264 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Name: Do you need to ask?! It's up there ^
I would be suprised if the 4 banger has the factory wiring setup like the 6 cylinders do.
#265 |
Towing Guru
For all intents and purposes the install of a brake controller in a 4 cyl will be the same as the write up I did for installing a brake controller in a 6 cyl non-tow package equipped truck. The only difference would be where to tap the brake signal from. There should be a harness and a plug attached to the brake switch attached to your brake pedal. With the brake pedal depressed you should get a 12 volt reading from one of the wires that you don't get when the pedal is not depressed. That is the wire you will want to tap for picking up the brake signal, then you run the other three wires into the cab and connect them to the brake controller as well, positive from the battery, ground, and output to the harness at the bumper. Sorry I can't be more specific there, but I do not have a 4cyl truck at my disposal to photograph or take voltage measurements from. If you complete this please do document it and add it in here as it would benefit other members as well.
Also, before you undertake this, make sure that the trailer you are looking at does in fact have electric brakes and not surge brakes. A lot of boat trailers have suge brakes as they as less prone to failure after repeated submergings at the boat ramp, particularly in salt water. You will also need to look into an adapter becasue if the boat trailer in question does have electric brakes it will likely use a 5-flat plug, and not a 7-round RV stye plug, so you'll need to adapt the 7-round to a 5-flat, which should be about 20 bucks or so. If I can help further or clarify anything please ask. Regards,
__________________
Maverick491 (Adam) ![]() DIY MODS Activator III brake controller Extra D-rings Aftermarket speakers w/TacoTunes mounting kit Illuminated 4wd switch ECO-2 VPE Scangauge II/Blendmount |
#266 |
That's just like your opinion, man
Interesting product. Just bought one of these to stabilize my hitch mounted hand truck dolly carrier: http://www.hitchrider.com/hitch-vise-fit-guide-2.htm
__________________
The Older I Get, The Faster I Was ![]() The quickest way of ending a war is to lose it. - George Orwell BakFlip Bed Cover Shorty Antenna Peripheral iPod Interface Garmin Nuvi RAM Dash Mount Add'l OEM Bed Tie Down Rings Westin Access Cab Nerf Bars (I think access cab bars look better on the Double Cab) Pop N' Lock Tailgate Lock Ideal Turn-Key Clamp (to secure tailgate) Spare Tire Security Cable Fumoto Oil Drain Valve WheelMaster Stainless Spare Air Hose Extender Redline Elite Hood Struts ProTecta Bed Mat |
#267 |
brake contoller help
Don't have directions with my drawtite activator and don't want to mess up anything. Controller has blue, black, white and red wires. I have jumper harness that came with truck but no directions. Which wires go together?
Thanks, Jay |
#268 |
Towing Guru
WHITE on your controller is ground. Connect to BROWN on your jumper harness.
BLACK on your controller is power. Connect to BLACK W/ RED tracer on your jumper harness. BLUE on your controller is signal output. Connect to RED on jumper harness. RED on your controller is signal input. Connect to GREEN W/ WHITE tracer on your jumper harness. SOLID GREEN on your jumper harness is the illumination circuit and is not used on your controller, just tape it up and ignore it.
__________________
#269 |
brake help
Thanks Maverick!
#270 |
Question??? Okay, so I've located the factory brake controller harness and noticed a different in the wire colors. The heavy gauge yellow wire is a heavy gauge blue wire. It still haves the light weight green, blue, and black&white. And I put a meter on it to determine that I had connector.
Another question, what's with all those unused connector? Thanks Rock |
#271 | |
#272 |
Thank you so much for the info, it really helped me out in knowing where to start with towing. Thx again.
#273 |
Maverick,thanks for putting this thread together!! Great timing from my perspective, we leave for Colorado pretty soon. will be pulling a 19' Airstream. Unfortunately I will not have time to do the rear spring mod, but packing as light as we can, not traveling with any water in any of the holding tanks, getting food once we get to Lake City, will help. I will adjust the WD hitch to make sure it's level..Let you know how it goes..Just curious, coming down off Monarch Pass, I plan on keeping the Tranny in 2nd gear. all that weight pushing on the transmission, for a long steep descent, ok??? Thanks,Jeff
#274 |
NIce post thanks!
#275 |
How come the book in my 04 double cab 4x4 says 7500lbs towing???
#276 |
Armor Tech Offroad
i dont see why it would hurt anything... just dont keep the revs to high and you should be fine.. on a long decent like that just remember not to ride the brakes.. use them when you need them to slow down a bit and then let off...
__________________
![]() 540-784-0197 kevin@armortechoffroad.com
#277 | |
I likr this truck.. Jeff |
#278 |
Armor Tech Offroad
glad to hear... one thing i used to do if i knew i was gonna be going down a steep long grade was to adjust the trailer brakes up a little more. this allowed me to just barely touch the brake pedal when the trailer started pushing real bad and that would engage the trailer brakes and help keep the trailer from going crazy. i always liked to really feel the trailer brakes grab when towing larger trailers anyways....
__________________
#279 |
great thread very informative. Im gonna be purchasing a TT jayco 22fb within a week, it uvw is 4100lbs, hitch weight of 410lbs im getting a wd hitch and prodigy brake controller. I live in buffalo ny so hills are not a big issue. Will i be good to go with this setup or do i need somethin else. Kinda gettin nervous bout buying it. No real long hauls either maybe 30-100 miles at most. thanks
__________________
07 dc trd offroad 4x4, flowmaster 40 delta flow, billys 5100's .85, courser at2 tires 265 75 16, custom sub box jl audio, tonneau cover my toy... 07 yamaha r6 w race header and muffler |
#280 |
I would like to build this small dump trailer for use behind my 2008 Taco 4 cyl with auto. Empty weight is 1311 lbs. and tongue weight (empty) is 220 lbs. I have the Hidden hitch class III installed with wiring. (Thanks to this forum)
Has anyone actually drove a regular cab/2wheel drive, within the 3500 lb limit? How did it handle? Did you require/recommend trailer brakes? I will only use this for once a month trips all under 30 miles fully loaded and no significant hills. Here are the plans I am building too> 8’x5' Air or Hydraulic Dump Trailer Model AD08 Plans http://www.trailerplans.com//index.p...emart&Itemid=2 Any recommendations/concerns? Appreciate the advise/help. |
| Display Modes | |
| Related / Mentioned Products |
| AFE Pro-Dry S Air Filter - $29.95 |
| Towing with the 2.7L I4 | Andy42 | Towing | 12 | 08-27-2009 08:45 AM |
| Towing Specs. for the 07 | Overstock07 | Towing | 10 | 10-23-2007 04:17 AM |
| Need receiver hitch? | missingthenw2001 | Towing | 20 | 09-27-2007 03:31 PM |
| towing with a V6 | michigantacoowner | Towing | 1 | 07-22-2007 07:58 PM |
| 4 cylendar towing??? | TacomaRyan | Towing | 15 | 05-07-2007 08:30 AM |
