The Tacoma Towing Bible
Old 10-29-2012, 06:30 AM   #661
this_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shedthis_is_nascar is one of the sharper tools in the shed
this_is_nascar's Tacoma Gallery
Originally Posted by this_is_nascar View Post
This weekend, I'm planning on installing my E2 Trunnion style WDH onto my Tacoma/Jayco 26BH. Is there anything, specific to the Tacoma, that I should be aware of? Obviously, I have the OEM tow-package and break controller already installed. I just wanted to make sure there wasn't anything specific to the Tacoma that I need to be concerned with.
Well, I got the trailer home safely and in one piece. I don't think I had the E2 adjusted to 100% the way it should have been, since I still had a good bit of sag in rear-end, but I did get it home. Now, I'll have time to properly get it setup and adjusted.
Old 11-08-2012, 08:51 PM   #662
Self Proclaimed first gen expert :doh:
Greensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shed
Greensystemsgo's Avatar
Greensystemsgo's Tacoma Gallery
Okay folks, at work, long day, frustrated searching.
Need to pull a 1999 ranger long bed single cab 2wd, busted tranny cooler/radiator. If in neutral, with little tranny fluid, will it be ok on car Dolley? Or should i borrow a double axle flat bed?
Pulling with my rig, 99 3.4 with expos out back, and elite offroad bumper with integrated hitch....
Old 11-08-2012, 08:52 PM   #663
Forgot to mention, only touring like ten miles. Gf got in a minor fender Bender.
Old 11-09-2012, 05:10 AM   #664
Unca Marty is on a distinguished road
Unca Marty's Tacoma Gallery
199 Ranger Long Bed on Tow Dolly
I recommend towing the ranger with the rear wheels on the dolly. This will prevent any damage to the transmission that may be caused by low fluid.
Just don't forget to secure the steering wheel securely so the front wheels stay straight. And don't rely on the ignition lock for this, use a stout rope or tow strap looped through the steering wheel so it can't move around the rim.
Old 12-15-2012, 09:52 AM   #665
JGstott is on a distinguished road
JGstott's Tacoma Gallery
New Guy towing question.
Okay, new guy posting here.
Considering buying '12 Tacoma DBL cab TRD w/tow package. Looking for smaller truck (have a '01 Dodge 2500), better milage, fits in my garage (its cold here!) We will also be switching to a towed pop/up camper. Really like the Palomino Banshee B-2 or B-3. Dry weight on the B-3 is 2900#. Total weight rating (wet trailer and cargo) is 3700#. Tongue weight (dry but with propane and battery) is 575# (actually weighed by the dealer). So with a loaded trailer I could easily get to 650# tongue weight.
We asked about pulling this camper with the tacoma, and the camper dealer recommended against it. They recommended 1/2 ton full sized, which is what I am trying to get away from (sucky milage, wont fit in garage). Further, the only advantage a 1/2 ton has is the bigger engine. The tundra's cargo capacity is pretty much the same as the tacoma, it's towing capacity isn't that much less.
Am I pushing the limits of the tongue weight in a dangerous way? Would a WD hitch make much of a difference? I appreciate the camper dealer's willingness to give their honest opinion, most dealers would just say 'sure you're fine, gimme your money."
Looking on this thread (which I have read the whole of- and its awesome) many folks are pulling much heavier loads with the tacoma and claiming no problems.
Thanks for the great info and any thoughts you more experienced folks have would be much appreciated.
Old 12-16-2012, 07:28 PM   #666
mikedgw is on a distinguished road
mikedgw's Avatar
mikedgw's Tacoma Gallery
Towing B3 Banshee with Tacoma TRD
JGstott:
Welcome toTacoma World Forums!
I have been towing a Palomino Yearling 4100 with a ’06 TRD Sport without any problems! (The Yearling is somewhat lighter than the Banshee but not much.) The only modifications I’ve made were to the truck’s brakes: I installed PowerTech front disks and also stainless steel brake lines at both the front and rear. My truck and trailer are level when towing and I have the standard 2006 TRD suspension set-up (only two leafs and one overload spring – typical for the 2006 model)!
Here are the towing specifications for a 2012 double cab V6 with the factory V6 Tow Package:
Tongue load (lb.) 640
Towing capacity (lb.) 6400
Safe towing requires a level truck and a level trailer. Note that safe tongue weight falls between 9 – 15% of the gross trailer weight. Per Palomino specs the weights on the Banshee B3 are:
Tongue: 384lbs
Gross: 3677lbs
Using the Palomino specs, your tongue weight would be 384/3677 = 10.44% which is within the 9-15% range. (If the tongue is too light, the truck & trailer will bob up and down and is prone to sway. If the tongue weight is too heavy, you will be overloaded and your headlights will point at the treetops!)
Light tongue weight can be corrected by shifting weight forward of the trailer axle. Heavy tongue weight is corrected by shifting weight behind the trailer axle.
Also, I’m curious as to how the dealer computed the 575lb tongue weight. Was the scale the dealer used set at the same height that the hitch ball will be on your hypothetical tow vehicle? If not his calculations are wrong.
Since the Banshee is not a high-wall and requires a folding galley I don’t think you will be able to fit a lot of stuff in there anyway. (I carry most of my camping gear in the truck bed in front of the truck’s rear axle.) As you noted you should have just one propane tank and one deep cycle battery on the trailer’s A frame.
Hope this helps!
Old 12-19-2012, 09:47 AM   #667
Thanks mikedgw!
Your info is as I thought but I appreciate the confirmation.
The Palomino dealer was really clear they they thought the published spec for the camper's tongue weight was just wrong. The tested it with propane and batteries, and got 575#. Not sure how they set up the test.
However, it seems like this is doable with a little prep and some minor reweighting.
Thanks so much for weighing in.
JGS
Old 01-10-2013, 09:57 PM   #668
mwa10taco is on a distinguished road
mwa10taco's Tacoma Gallery
I've just bought a 2010 Taco Dbl Cab TRD Off Road w/ a Towing Pkg, and I'm not able to spot the kick panel connector for the trailer brake controller. I've got the plug to connect, but can't find the one on the kick panel. In my defense, I'm not the first guy under that dash, there is an alarm system installed w/ a pot load of little wires scotch-locked to a myriad of factory wires. ( A pox on techs paid by the hour to install such unnecessary crap.) There were 3 plugs (w/ connections on both sides) kind of taped together w/ some plastic crap that were immediately above the top of the kick panel, but they looked to be part of the original wiring w/o the trailer stuff. If I hadn't looked at the plug under the rear bumper I would be doubting the presence of the tow package. Anyone got a suggestion for exactly where to look and what color wires are in it? Is it supposed to be fastened to something or otherwise disguised?
Old 01-12-2013, 09:15 PM   #669
k kids, heres what i learned today. dunno if it will help any.
had a mechanic buddy take a look, and after alot of head scratching we both decided, sure enough we need that converter doodad.
it is possible to wire it up without one, BUT you will have your turn signals on your truck on if you have the right blinker on, on the trailer. blow back
so went out and bought this. http://www.oreillyauto.com/site/c/de...0421&ppt=C0386
Now normally, and ill agree, DO NOT CUT UP YOUR HARNESS, get this!
http://www.oreillyauto.com/site/c/de...1&ppt=C0386#at
But in my case, i already had the wiring in place from that, from the dealer actually, so i simply used the wires meant for the trailer.
wheeee
Old 01-16-2013, 06:01 PM   #670
way to hold a 4-flat plug
Originally Posted by tacomaman06 View Post
yeah.....kinda like the 2nd link, but without the 7 wire round plug. can i get just a bracket for the 4 wire to keep it from hanging, or would i be better off just making one?? shouldnt be too hard to do.
You can get a bracket for a 7-pin receptacle and use a Romex wire clamp that just fits it. It will be wide enough to clamp the 4-flat in it and hold it tight.
'98 Ranger Supercab 4x4 Off-Road
'10 Tacoma Dbl Cab 4x4 Off Road
'02 Civic SI
'96 Impala SS w/ CLIII hitch and Air Lift bags + (usual stuff and for sale)
Old 02-26-2013, 04:52 PM   #672
Hollywood218 is on a distinguished road
Hollywood218's Avatar
Army: Maint. Team Leader/Recovery NCO
Hollywood218's Tacoma Gallery
My apologies if this was already answered, but when figuring out the tongue weight of a TT, do I include the WD hitch weight? (95 lbs. shipping weight) Also, does a WD hitch have any effect on the tongue weight capacity? I am looking at buying a 2002 Fleetwood Coleman Caravan 25SLB, and I can only find the dry weight and GVW. I am not having any luck finding any kind of published tongue weight, and as of right now, that is what will make or break the deal. Thanks!
Old 03-02-2013, 08:57 PM   #673
psmcn is just really nicepsmcn is just really nicepsmcn is just really nicepsmcn is just really nicepsmcn is just really nice
psmcn's Tacoma Gallery
Once you start to conciser the WD system the TW pretty much goes out the window but you should try to stay close to your trucks max TW. The hitch on the tacoma is a class 4 hitch. If it was on a bigger truck it could be rated up to 10.000lbs with a TW of 1000lbs. Because of the Tocos lighter weight and smaller drive-train it is rated at TW 650 and a trailer weight of 6500. These numbers are for a single ball mount TW with the MAX Trailer weight. Once you put the WD hitch on it is a matter of equalizing your TV and trailer using the WD system and making sure you have a strong enough system to handle the weight you are trying to distribute. You should never go over the max trailer weight rating or truck cargo rating though. ANything, cargo or weight added aft of the rear axle is considered as part of the TW. This is why you adjust a WD hitch with your TV and trailer loaded. When my rig is loaded I with bike in the truck and full tank of water with full LP tanks an two Batts. I have to really crank the WD system to get it level but it works fine and my truck handles great.
Here is a link on hitched
http://www.etrailer.com/faq-weightdistribution.aspx
Here is a link on how to measure TW
http://hildstrom.com/projects/tonguescale/index.html
A pic of my rig completely loaded.
Hope this helps.
Paul
Old 03-03-2013, 07:13 AM   #674
@PSMCN:Thanks a bunch! That answers all my questions! The TT GVW is 5500#/dry 4200#, so even maxed out, the trailer will be under the max by at least 1000#. Another thought I had to help put less stress on the hitch/tongue was to place the two LP bottles in the bath tub in the back of the trailer during transit. I have purchased the TT, I just have to wait for the WD hitch and the brake controller to get here some time this week. Thanks again psmcn!
Old 03-03-2013, 05:22 PM   #675
Leave the tanks were they belong. You want them secure for safety reason that I think you can understand. When you get your WD system load your trailer and truck then set up your hitch. I hope you got the 8-10K lb hitch for your rig. Anything else would be to light. I think you will be fine with the TW. Take your time when you set it up, take it for a drive then adjust it as may be needed. My trailer is a little over 4K lbs loaded. With the Taco I know its pulling that weight but I have never had the "white knuckle" experience that some talk about. My rig is steady and I can feel comfy with one hand on the wheel. I never exceed 65mph it makes the Taco work to hard with the wind resistance. I don't know what type of hitch you are getting. I have the equalizer and it has worked great after I got it set correctly.
A pic.
Notice the bars are parallel with the frame of the trailer. This is the correct position for every system I have seen. If they are low or hi to find your proper level of the TV follow the instructions to level the bars until you have the desired weight distribution.
I will send you a PM with my email address.
Paul
Old 03-13-2013, 03:56 PM   #676
7.62x63mm
goufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shedgoufcustom is one of the sharper tools in the shed
goufcustom's Avatar
Navy: NAVAIR
goufcustom's Tacoma Gallery
I think I know the answer, but I am new to towing. I am borrowing a friends 18' open landscape trailer to go pick some furniture up, when the trailer is empty, can I leave it in D (overdrive) or should I still put it in 4?
I have an Auto 2nd gen V6 with factory tow package.
ETA: nevermind, buddy brought over the trailer and it is a lot bigger than I thought, without a doubt need to take it out of overdrive to pull this thing.
Old 03-15-2013, 06:43 AM   #677
TXfutballer is on a distinguished road
TXfutballer's Tacoma Gallery
Tow Package vs. No Towing Package
Toyota lists the Towing Capacity of my V6 at 3500# and 6500# w/ Towing Package. The V6 Towing Package includes: Class-IV receiver hitch, transmission and supplemental oil coolers, 130-amp alternator, heavy-duty battery, 7-pin connector and Trailer-Sway Control.
My truck does not have the Towing Package and 3500# seems a bit light. I will be adding a receiver hitch (and plug/pin) but the question becomes, Class-III or Class-IV.
Certainly, the battery and alternator are easy enough to upgrade.
I have been lead to believe that my truck is capable of 6500# (or close to) but Toyota is low to admit such without a Towing Package.
Anyone...anyone...Bueller?
Old 03-15-2013, 09:11 AM   #678
Devout Atheist
piercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shed
piercedtiger's Avatar
piercedtiger's Tacoma Gallery
Send a message via AIM to piercedtiger
I think that rating is due to the extra equipment: bigger battery/alt to help power trailer brakes/lights/etc, oil/tranny cooler to keep engine/tranny from overheating, and the heavier duty hitch.
The problem you will run into is the oil cooler. Many have doing a tranny cooler I think, but the engine oil cooler is expensive. I want to say someone on here or Toyota Nation priced it out at 2x$500 for the major parts, plus a few other things.
Old 03-15-2013, 10:55 AM   #679
Coolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shed
Coolerman's Avatar
Coolerman's Tacoma Gallery
I think the 3500 rating is assuming that you are putting a ball on the rear bumper.
Old 03-17-2013, 07:00 PM   #680
There is so much hemming an hawing about putting the auto trans in 5th or 4th. In my 08 Taco manual it says to run it in 4th when pulling a trailer to assist with engine braking. Thats it! If you can drive your truck in 5th and it stays in 5th while hauling, leave it in 5th. If it is hunting from 5th to 4th at fairly short intervals then put it in 4th. On flat ground I can run my rig in 5th with no problems. When I hit the hills I put it in 4th. I have pulled a 22ft flatbed empty in 5th with no problems and loaded in 5th as well. You just have to feel it out. Furniture is not heavy and should not cause a lot of strain on the Taco.
I run in 5th with this set up as well.
Favorite Bible verse hoosiertaco Off-Topic Discussion 73 03-14-2013 11:56 AM
The 12V DC Wiring Bible from pirate KalamaKid General Automotive 1 09-02-2011 12:37 AM
Recovery Bible [pirate4x4.com] solidcopy Off-Roading & Trails 1 07-10-2010 12:06 PM
Wheel and Tyre Bible taconinja Wheels & Tires 1 10-08-2008 11:05 AM
Autographed Bible for Sale! Khaos Off-Topic Discussion 9 08-30-2008 07:26 PM
