The Tacoma Towing Bible
Old 03-17-2013, 06:57 PM   #681
anarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shedanarion55 is one of the sharper tools in the shed
anarion55's Avatar
anarion55's Tacoma Gallery
On the money...
I can attest, from years of towing our 28', 6-ton (loaded) toyhauler - with a Silverado 2500HD Duramax/Allison, the OP's info is 100% correct. I wish it had been out there when I was first starting towing.
I whole-heartedly recommend the Prodigy brake controller... it has performed flawlessly from the moment it was installed.
We chose to replace the OEM unit with a Putnam hitch, as it has a significantly higher rating than the Drawtite or Reese units (16,000/1600). The stock Chevy hitch at the time had a reputation for catastrophic failure (i.e. coming apart while towing).
The only other thing I would add is, take your fully loaded trailer to a certified CAT scale (truck stops often have them). For under $20 you will know your EXACT gross trailer weight and tongue weight. If it's a slow day, and you can spare a few bucks more, you can even get the weight on each axle of the trailer and truck. In Mav's bible, he says the weight of your trailer will surprise you, and get very heavy, very easily...I fully concur with that. In addition, trailer manufacturers often list the trailer weight BEFORE any options (like the genset, bbq grill, tv, etc.) are added. Water & fuel contribute significantly to the weight (our toyhauler holds 150 gallon of fresh water, and 50 each of black & gray... though they are almost never all full at the same time, that' a total of 2075 lbs!). All before loading our bikes...
WEIGH YOUR RIG!!!
Old 04-19-2013, 10:42 AM   #682
TuckerTacoma is on a distinguished road
TuckerTacoma's Avatar
TuckerTacoma's Tacoma Gallery
With two added leafs in the rear is doesn't sag to much.
26' Sea Ray Sundeck and 20' goat trailer
The Tacoma Towing Bible-402788_414645108593599_1229613939_n.jpg   The Tacoma Towing Bible-374412_446566468734796_926020933_n.jpg
Old 04-25-2013, 03:09 PM   #683
Yayarisa is on a distinguished road
Yayarisa's Tacoma Gallery
Do you have any recommendations on after market transmission oil coolers. The dealer charges $800 just for the part. Installation extra. Or is that the going rate? I thought I'd be looking at around $300-$500 total. I have a 2011 SR5 without tow pkg. Towing a 3500 pound rv.
Old 04-25-2013, 03:17 PM   #684
Coolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shedCoolerman is one of the sharper tools in the shed
Coolerman's Avatar
Coolerman's Tacoma Gallery
I don't know about the quality but Dorman makes one that i have seen on ebay for as low as $178.50.
Old 04-26-2013, 08:15 AM   #685
HB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shedHB Taco is one of the sharper tools in the shed
HB Taco's Tacoma Gallery
looks good, that's a good size boat how much does it weigh?
Old 04-27-2013, 04:45 AM   #686
26' Sea Ray
According to the Sea Ray website it has a dry weight of 5,100 lbs. I don't know if thats the trailer or not but its pretty heavy back there. Before I added the leafs it sagged pretty good.
Old 04-28-2013, 03:29 PM   #687
anarion55's Avatar
Just so you know...
The "stated" weight is RARELY accurate, especially if you have had options added on. The only way to know the ACTUAL weight of your rig is to weigh it on a certified scale.
Old 05-01-2013, 07:25 AM   #688
romafern is just really niceromafern is just really niceromafern is just really niceromafern is just really niceromafern is just really nice
Army: 66H8A5K- 9a     so if you like visiting my page here, let me know what where you looking for.
romafern's Tacoma Gallery
Originally Posted by ajohnson View Post
I mounted mine below the flip-out tray. I keep my hitch and coupler lock keys in the tray.
this is how I have mine but I did NOT drill any holes. Instead, I used a large binder clip and presto!
Stays put and does not move at all. And is out of the way. I just can't see myself drilling holes in the cab control panel finish....
If you want pics, pm me.
Later, stay safe!
Old 05-01-2013, 07:40 AM   #689
Originally Posted by TXfutballer View Post
Toyota lists the Towing Capacity of my V6 at 3500# and 6500# w/ Towing Package. The V6 Towing Package includes: Class-IV receiver hitch, transmission and supplemental oil coolers, 130-amp alternator, heavy-duty battery, 7-pin connector and Trailer-Sway Control
Anyone...anyone...Bueller?
What is this? (sway control feature) New feature on the Tacomas? Got pics? Never heard of it.
Educate me on this pls. Towing this summer from east coast to west coast a Big Tex Utility tandem 14' trailer with all my toys.
Cheeers!
Old 05-01-2013, 01:34 PM   #690
anarion55's Avatar
Cheeers!
It's done electronically, using the ABS system to rapidly brake one side or the other independently, when sway is detected (again, by the ABS). Haven't had any instances where I've noticed it in action, so I can't say how well it works, but theoretically it should help in controlling sway.
Old 05-01-2013, 06:09 PM   #691
^^^^ Really? umm...interesting. I hope I never get to use/experience it.
Old 05-01-2013, 06:29 PM   #692
anarion55's Avatar
I believe it's done so subtly that there's a good chance you might never even know it activated, or that there was sway at all. But I can't say from personal experience.
I can tell you that we towed a Uhaul box trailer 700 miles last weekend, almost all on the interstate, and I never felt any sway at all, even when passing/being passed by 18-wheelers, or in gusts of wind (there were several t-storms that day).
I know what sway feels like - when towing our 28', 6-ton toyhauler (not with the Taco - we use a Silverado 2500HD Turbo Diesel), every time an 18-wheeler goes by, i have an exercise in steering control. And we have an anti-sway, load-distribution hitch on that rig. The Taco, while admittedly not nearly as loaded, showed none of that.
Maybe it was the electronic anti-sway...
Old 05-06-2013, 02:47 PM   #693
bretts is on a distinguished road
bretts's Tacoma Gallery
OK - from what I have gathered, I probably should NOT be towing with my taco... but just for shoots and ladders, if I was to move a travel trailer about 300-400 miles once a month... would it even be possible?
I'm thinking about getting a 20' as max in size with all the hook ups so no tanks would be filled as I'd set it up at parks and leave it there when I go back home... basically trying to get a cheap alternative to renting motel rooms as it is out of town work.
I have a base model bone stock 96 taco with 70k miles. No towing package added, but of course I'd get the class3 w/ a trans cooler if needed.
Old 05-06-2013, 03:30 PM   #694
Devout Atheist
piercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shedpiercedtiger is one of the sharper tools in the shed
piercedtiger's Avatar
piercedtiger's Tacoma Gallery
Send a message via AIM to piercedtiger
What's the weight of the trailer and what is the truck rated for?
Old 05-07-2013, 06:40 AM   #695
The truck is rated at ~3500lbs, but I would take that with a grain of salt.
The trailers I am looking at are Casita Travel Trailers, and the 13' is 1900lbs dry and the 16' is 2200lbs dry. Now, I'd move it to the job site and set it up and leave it there. So I'd only move it once or twice a month. I'd much rather buy a nice new trailer than have to buy a new truck and a cheap older trailer...
Old 05-07-2013, 01:36 PM   #696
Devout Atheist
You'd probably be good with either of those weights. Up hill or mostly flat?
I'm fairly certain I exceeded the 6500 lb rating on my 06 double cab with tow package. Nothing broke, and it handled fine with proper load balancing. So the 3500lb rating is probably a low estimate from Toyota for safety reasons. The class 3 hitch is rated for 5000lbs anyway, so the 3500lbs for the truck is based on brakes, weight of the truck, horsepower, etc.
Old 05-09-2013, 03:13 PM   #697
Lennnie is on a distinguished road
Lennnie's Tacoma Gallery
Running gear question
Hi, very nice writeup. I just bought a new trailer/toy hauler to take my motorcycle places and brought it home today. I drove the 200 miles from the dealers home in drive. Your article if i'm reading it correctly suggests that I should drive in third gear. Do I have that correct? Thanks, len
Old 05-10-2013, 03:45 AM   #698
J Gibson is on a distinguished road
J Gibson's Avatar
Navy: Hospital Corpsman, 4th MarDiv
J Gibson's Tacoma Gallery
I tow a travel trailer that weighs around 4700 lbs. i personally leave mine in drive unless the transmission is hunting, (shifting back and forth between gears). I figure I should trust the Toyota engineers to have done their jobs. I definately get better gas mileage in drive and the TFT on the scangauge doesn't seem to drop much, if at all, in a lower gear.
Old 05-10-2013, 04:51 AM   #699
TRDZR2 is on a distinguished road
TRDZR2's Tacoma Gallery
I have the Reese dual cam and my bars are not level to the frame, the angle down by design. They are different depending upon brand, design, amount of weight transfer needed, hitch height etc.
Originally Posted by psmcn View Post
Notice the bars are parallel with the frame of the trailer. This is the correct position for every system I have seen. If they are low or hi to find your proper level of the TV follow the instructions to level the bars until you have the desired weight distribution.
Paul
Old 05-14-2013, 10:55 AM   #700
unless its payday, im drinking natty ice
sickspeedTX has much to be proud ofsickspeedTX has much to be proud ofsickspeedTX has much to be proud ofsickspeedTX has much to be proud ofsickspeedTX has much to be proud ofsickspeedTX has much to be proud ofsickspeedTX has much to be proud ofsickspeedTX has much to be proud ofsickspeedTX has much to be proud ofsickspeedTX has much to be proud of
sickspeedTX's Avatar
Navy: Mechanic
sickspeedTX's Tacoma Gallery
any tips for towing with a m/t? this seems geared more towards the a/t crowd.
Favorite Bible verse hoosiertaco Off-Topic Discussion 73 03-14-2013 10:56 AM
The 12V DC Wiring Bible from pirate KalamaKid General Automotive 1 09-01-2011 11:37 PM
Recovery Bible [pirate4x4.com] solidcopy Off-Roading & Trails 1 07-10-2010 11:06 AM
Wheel and Tyre Bible taconinja Wheels & Tires 1 10-08-2008 10:05 AM
Autographed Bible for Sale! Khaos Off-Topic Discussion 9 08-30-2008 06:26 PM
