-   -   Factory Hitch and wiring harness install (http://www.tacomaworld.com/forum/towing/159296-factory-hitch-wiring-harness-install.html)
oldtimertoyota 05-27-2011 08:28 PM
I'm just wanting to get an idea of what I am getting myself into installing the factory hitch and wiring harness. I have an 09, 4 door, SB, 4X4 base model Tacoma, the hitch looks easy but looking at the instructions for the wiring harness it looks like the install could be kind of a pain. The dealership quoted me 1.5 hrs just to install the wiring harness which means that would be about $160 which seems a bit much. Anyone install a factory harness and is it worth spending the $160 not to mess with it, or is it like most instruction manuals which make things looks more complex then they actually are.
fletch aka 05-27-2011 08:47 PM
Maybe something here will help you.
http://www.tacomaworld.com/forum/tow...ing-bible.html
oldtimertoyota 05-28-2011 07:01 AM
I had seen that but that looks like the install for the aftermaket wiring harness which I believe hooks up differently.
RLDTACO 05-31-2011 06:46 AM
It took me approx. four hours to install the OEM wire harness. If you read the instuctions and take your time should be no problem. I installed the hitch first then the wire harness. There is alot of info in the towing section of TW, may find some help there also. Hope this helps.
RLDTACO 05-31-2011 10:53 AM
Originally Posted by dhk (Post 3243989)
WOW, YOU'RE SLOW!!!!
Seriously, you can make it *work* in under 5 minutes by just snapping everything into their sockets. It shouldn't take 4 hours to run the wire and zip tie it off to the main tail light harness.
Five minutes! :eek: I need you to come and work on my truck.:D
oldtimertoyota 06-02-2011 07:22 PM
Hey thanks for responding, I just got the factory hitch and harness today, I can see after looking at the directions this being a fairly lengthy process and I am picky so I will take my time. The installation manual looks like it is pretty detailed so that should help. I too will start with the hitch and then mess with the wiring harness after that. I'll post when I complete things and tell you how it went for me.
RLDTACO 06-03-2011 07:04 AM
Sounds like you have it under control. I'm picky about my truck also, so I searched for info on the web and took my time and really had no problems. The most difficult thing was reaching up under dash area to make the connections. Not sure what your towing but run the wires for a brake control at same time. (If you need it) Bob
g7evans 06-12-2011 08:49 AM
I am getting ready to purchase the same hitch and wiring connection. what type of connection does the OEM wiring harness come with? 4 5 or 7 prong?
TerryS 06-12-2011 09:04 AM
As far as I can tell, the Toyota harness only comes with a 4 prong plug.
OP: Installation wasn't hard (and I'm not a so young anymore), but I took my time. 4 hours sounds about right. The worst part was the wire connections under the dash, but only because it's so tight.
g7evans 06-12-2011 09:08 AM
i am only towing a a 16ft alum boat and my trailer does not have breaks on it. all i need is to connect the trailer lights. will i still have to run wires up under the dash if i dont need the breaking connections?
TerryS 06-12-2011 09:28 AM
No, IMHO, you don't really need the Toyota wiring harness. It makes a separate dedicated & fused circuit for trailer lights, but I don't think it 's absolutely necessary for your little boat trailer. You can get the plug-in variety of trailer wiring at your local auto parts store, RV store, tractor supply, or even online. 15 minute installation, tops, but it powers directly from the tail lights & directionals. Here's a link to a video that shows how it's installed on an older Tacoma.
http://www.youtube.com/watch?v=EgajKpMgZpE
g7evans 06-12-2011 09:35 AM
sweet. thank you very much. i am assuming you just saved me alot of headache
Cr250jumper 06-12-2011 01:58 PM
I bought one of those etrailer light harnesses. Its a 4 plug but since you dont have trailer brakes thats fine. Installed in less than 30 minutes including tucking in all the wiring. Super easy
oldtimertoyota 06-12-2011 09:45 PM
I have not had time to install the harness yet as I am in the process of moving, though I was actually hoping to have it done for the move. Thanks for the info, under the dash is never fun!
oldtimertoyota 09-17-2012 07:44 PM
Figured I'd update this thread. Just completed installing the OEM wiring harness, it did take me around 4 hrs. I took my time. Under the dash and figuring the correct route to the hitch were a little tricky but definately not beyond most of us with basic mechanical skills, This thread is over a year old, I think I'm ready to haul a trailer now:D
howard1945 09-23-2012 03:13 PM
Is the Wiring Harness installed
I have a 2012 Tacoma with towing package. I can't find the wiring harness. I have a package of wiring but I think this is for brake on trailer. Is there a light connection for trailer install and tucked away somewhere?
oldtimertoyota 09-23-2012 10:28 PM
If you bought it with the tow package you should definately have a flat 4 connector, if the 2012 model is the same as the others I've seen it should sit a little left of the center of the hitch and be attatched to the hitch, it is a little hard to see and actually looks small.
shemp 09-24-2012 06:41 AM
The hard part dealing with the factory wiring harness is just routing the wire itself from the cab to the bumper. As I recall, the rest of the process was quite literally just snapping in a few modules, relays, and fuses.
howard1945 09-24-2012 09:09 AM
Thanks I found out I have to have an adapter to go in the large round plug to the left of hitch
othater 11-20-2012 08:35 PM
Which OEM tow wiring harness did you buy?
The one with the 4 pin connector?
Who did you buy from and cost?
