How much can I put in my tacomas bed?
Discussion in 'Towing' started by focotacoma, Jun 15, 2011.
  1. Jun 15, 2011 at 7:58 AM
    focotacoma
    focotacoma [OP] Well-Known Member
    Fort Collins
    07 Speedway Blue 4x4 TRD off-road
    Im getting there......
    I guess I should say did I put to much in my tacomas bed. I was helping a buddy out and made six trips each with a 1 and 1/2 tons of mulch in the back of the truck according to the scale at the landscaping supplier. Is that too much? My truck didn't seem to sit hardly at all into the suspension, but it did make squeaking noises. I would look at the manual but I dont understand any of the weight ratings they give.
  2. Jun 15, 2011 at 8:09 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    1 1/2 tons in a 1/3 ton truck is a lot
  3. Jun 15, 2011 at 8:10 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    I thought the max payload was around 1400.
    I think toyota overbuilds so you should be fine but I imagine you wouldn't want to load up a ton and a half and leave it in there all the time.
  4. Jun 15, 2011 at 8:11 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Was your exhaust pipe draggin'? :p
  5. Jun 15, 2011 at 8:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, that's a little much... How did you even fit that much in the bed, 3,000 lbs of mulch is usually pretty large volume-wise.
  6. Jun 15, 2011 at 9:21 AM
    focotacoma
    Fort Collins
    well it was piled above the beadsides and it was a bit wet from rain but it was piled about as high as the cab in the center of the bed and rounded out to the side height pretty much completely filling the bed. And the suspension wasn't hardly compressed at all. In fact it made it about level....
  7. Jun 15, 2011 at 9:25 AM
    Pugga
    Massachusetts
    was it planted on the bump stops?
  8. Jun 15, 2011 at 9:35 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Isn't that double the limit? :eek:
  9. Jun 15, 2011 at 10:42 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    LOL probably that, and he didnt notice it:p
  10. Jun 15, 2011 at 10:46 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Do a Ctrl+F on this page... the info is in there. It's Wikipedia, so consider the source, but it looks right.
  11. Jun 15, 2011 at 10:48 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    thats way to much for a tacoma
  12. Jun 15, 2011 at 10:51 AM
    mws4ua
    Birmingham
    This.
  13. Jun 15, 2011 at 10:53 AM
    Pugga
    Massachusetts
    Was thinking the same thing until he mentioned he was weighed at the supply house's scale. It probably did sit level, once your on the bump stops, you're not going to squat any further.
  14. Jun 15, 2011 at 11:00 AM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    i wouldn't worry about it, between the 4 tacomas i've owned i've overloaded every one of them way over factory specs with either gravel, mulch, wood or dirt at one time or another. The main thing is don't let it sit in the bed too long becasue it can warp your springs
  15. Jun 15, 2011 at 11:00 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Dakars would help drastically!!
  16. Jun 15, 2011 at 11:01 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    loaded with 30 bags of mulch, however many yards that would come out to...lol
  17. Jun 15, 2011 at 11:03 AM
    mws4ua
    Birmingham
    How heavy are those bags? If 50lbs each, that's just 1,500lbs total, which means it's HALF what the OP put in his.
  18. Jun 15, 2011 at 11:07 AM
    kmok
    Kyle
    Columbus, Ohio
    Probably 40-50lbs or so. I don't know how the OP could fit more than that in his truck with his DCSB.
  19. Jun 15, 2011 at 11:20 AM
    Dan05
    Dan05 Member
    Dan
    Little Rock, AR
    '05 V6 4x4
    Challenge accepted.
  20. Jun 15, 2011 at 11:21 AM
    mws4ua
    Birmingham
