Prodigy P2 Brake Controller
Discussion in 'Towing' started by Rocknroll, Jan 3, 2012.
  1. Jan 3, 2012 at 10:53 PM
    Rocknroll
    Rocknroll [OP] Well-Known Member
    Devin
    Ventura County, CA
    2020 TRD Offroad DCLB 4x4
    When connecting the Toyota supplied jumper to the Prodigy supplied connection, do i need to connect the solid green wire to anything?
  2. Jan 5, 2012 at 5:46 PM
    ruger1
    ruger1 Active Member
    Western NY
    2011 TRD OFFROAD
    rear tsb, bilstein 5100's all around, trd exhaust.
    I have a prodigy controller and i think the only extra wire was a ground wire that came from the controller harness.
  3. Jan 6, 2012 at 7:19 PM
    Rocknroll
    Devin
    Ventura County, CA
    I found an easy way. There is a wiring adaptor that plugs into the factory plug. You don't need to connect any wires. I picked up the Tow Ready #22285 adaptor. You can also get the Tekonsha #3040P. Tow Ready and Tekonsha are both owned by the same company, so it doesn't matter which one you get.
    Now I just need to get a trailer with brakes so that I can try it out!
  4. Jan 11, 2012 at 10:19 AM
    Woodstocktaco
    Woodstocktaco Well-Known Member
    Woodstock, GA
    09 SR5 ORDC 4X4
    3" OME lift, 885 coils, Dakar rears, diff drop
    I just picked up the 3040P harness with my Prodigy P2. Had it out of the box & hooked up within 10 minutes. Hope to try it out this week on the trailer if it ever stops raining here.
  5. Jan 12, 2012 at 7:26 PM
    Woodstocktaco
    Woodstock, GA
    09 SR5 ORDC 4X4
    Big thumbs up for the Prodigy P2! The owners manual is far more complicated than the actual operation of it. After today's test drive I can honestly say it's a small investment for a lot of peace of mind.
  6. Jan 13, 2012 at 8:05 PM
    Rocknroll
    Devin
    Ventura County, CA
    Got to use mine today also. Brought home a camping trailer. Worked great - I love those plug and play devices. Very easy setup and use.
  7. Feb 22, 2012 at 3:47 AM
    MTT12
    MTT12 New Member
    Where did you mount your P2?
  8. Sep 6, 2012 at 7:03 PM
    DenisSeattle
    DenisSeattle Well-Known Member
    TRD Off Road
