-   -   transmission cooler for 4cyl taco (http://www.tacomaworld.com/forum/towing/244480-transmission-cooler-4cyl-taco.html)
themeat424 10-17-2012 11:21 PM
I posted this in the 4 cyl section, but I think I might have a better chance getting an answer here. Can someone tell me if there is a difference between the aftermarket transmission coolers for the V6 5 speed tacos vs the 4 cyl 4 speed tacos? Basically, do I need a cooler of a different size being that the transmission has one less gear and I'm guessing holds less fluid? Or are they essentially the same and the hayden 678 that others have installed in their V6 trucks a good fit for the 4 speed trucks too? Thanks!
wolftree 11-25-2012 05:45 AM
The Hayden 678 or it's equivelant B&M cooler will serve you well.
