-   -   Factory Transmission / Oil Cooler (http://www.tacomaworld.com/forum/towing/265175-factory-transmission-oil-cooler.html)
yukongeoff 02-24-2013 10:23 PM
Hello,
How do I tell if I have a factory transmission cooler and/or oil cooler installed? I tried to look but it didn't jump out at me.
I have a 2010 V6 SR5 double cab, I have a factory 5000 lbs receiver hitch and 4 pin wiring....
Thanks,
Geoff
GAgeorge 03-06-2013 05:35 PM
Would like to know myself
scottg918514 03-12-2013 05:34 PM
Originally Posted by yukongeoff (Post 6494728)
Hello,
Thanks,
Geoff
Just picked up a 2013 last week with tow. I've towed for years, so I thought I knew what to look for. If you have automatic, the transmission cooler or transmission oil cooler looks like a small radiator in front or behind your actual radiator. Manual trans don't have a transmission cooler (I have a manual).
The oil cooler puzzled me. Typically, another small radiator in front or behind radiator, but factory oil cooler on the 4.0 L is a small device right under the oil filter. Can someone confirm this?
S.B. 03-12-2013 06:24 PM
from there the oil goes into the radiator.
yukongeoff 03-13-2013 10:54 AM
I still haven't figured it out for sure, I have a dealer appt booked next month and am going to get them to check. They told me on the phone that on certain models the trans cooler is inside the radiator so it wouldn't be immediately obvious. I will let you know when I find out for sure.......
S.B. 03-13-2013 07:38 PM
The towing package cooler is right behind the top portion of the bumper and the driver's side. It's about the size of an envelope.
salvesg 06-05-2014 08:15 AM
jorge
The V6 Towing Package with the Automatic transmission should include 2 separate types of coolers.
An engine oil cooler located at the base of the existing oil filter unit.
An auto transmission fluid cooler located as mentioned near the front radiator.
These are two separate coolers for the two different types of fluids.
hope this helps
gearcruncher 06-05-2014 08:30 AM
Here is the transmission cooler
http://www.customtacos.com/tech.old/...a/02700910.pdf
Here is the engine oil cooler . Cant beleive how small this critter is ?:confused:
http://www.customtacos.com/tech.old/...a/01800510.pdf
