Advice on Disconnecting the drive shaft
Discussion in 'Towing' started by katepace, May 7, 2013.
  1. May 7, 2013 at 1:57 PM
    katepace
    katepace [OP] New Member
    Tacoma 4x4
    I'm going to be towing my 01 4x4 Taco on a tow dolly from MT to NC. I know I need to disconnect the drive shaft before it can be safely towed. Any advice or suggestions on how to do this most efficiently?
  2. May 7, 2013 at 2:03 PM
    gasgasman
    gasgasman Well-Known Member
    Why not put the transfer case in neutral?
  3. May 7, 2013 at 2:05 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Unbolt it at the rear differential and secure it very, very, very well to the frame (make sure the slip joint can't be pulled apart). If that's not possible, then you need to unbolt it at both ends. Mark the flanges so you put it back the same way.
  4. May 7, 2013 at 6:06 PM
    03stepsidetaco
    03stepsidetaco Member
    David
    centralcoast CA
    03 stepside taco
    X2
