-   -   How easy is it to add a 4-wire plug to the factory towing harness? (http://www.tacomaworld.com/forum/towing/279584-how-easy-add-4-wire-plug-factory-towing-harness.html)
Ray 05-26-2013 06:52 PM
I have an '09 TRD with the OEM tow package. I would like to add a flat 4-wire plug to the harness so that I can use a receiver mounted brake lamp. There are aftermarket systems available that require some type of in-line module but can I just identify the proper wires and splice into them to power the flat 4-plug?
Thanks,
Ray
Tacoyota 05-26-2013 07:05 PM
gotta redo this , too big of a link..... they make adapters, sells anywhere like home depot , auto shops or boating shops.
http://t1.gstatic.com/images?q=tbn:A...YmzXe6YSDVkGdO
Ray 05-26-2013 07:13 PM
I have an adapter.....but there are times that I need to hook up to both the 7-pin and would like to have a flat 4-wire also.
Ray
Tacoyota 05-26-2013 07:15 PM
http://t3.gstatic.com/images?q=tbn:A...UXuimNmihtphZnhttp://www.homehardware.ca/en/rec/in...I8730023?Num=0
like that? Hell I never seen or used anything like it, just 6.7. 4flat.
Ray 05-27-2013 07:32 AM
I think that I may have found what I've been looking for!
http://www.hopkinstowingsolutions.co...pkg_08-10.html
Ray
