-   -   Help locate harness (http://www.tacomaworld.com/forum/towing/280725-help-locate-harness.html)
melonman 06-03-2013 04:59 PM
Help locate harness
Greetings ,
I have a 12 Tacoma with the towing package . I've looked for the factory plug above the left kick panel and cannot locate it . I guess I may have to remove the kick panel , I do not know how to remove the left foot rest which the kick panel is secured by . Please help .
Kevin
flyingpostman 06-04-2013 09:49 AM
It should be fairly easy to remove the kick panel, if I remember correctly the sill plate has to come out first. The plug is there, often pointing upwards towards the back. Took me a while, but I found it. Move the driver seat all the way back and lay in there and look upwards and use a small bright flashlight. Awkward, but it will help.
WHPLSH3 06-04-2013 11:59 AM
On my '12, it was behind the big spaghetti mess under the kick panel. You really need to feel around...
