Pre Runner Trailer Hitch Help
Discussion in 'Towing' started by jbu9136, Jun 9, 2013.
  1. Jun 9, 2013 at 1:19 PM
    jbu9136
    jbu9136 [OP] New Member
    13 Prerunner SR5
    I just bought a new Pre Runner SR5 with the big tires and a tow package. The hitch is quite a bit higher than my old hitch and I'll need a drop down hitch. Any recommendations on the drop down hitch for the SR5 receiver? 2, 3 or more inches? I'm pulling a bass boat.
  2. Jun 9, 2013 at 1:27 PM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    i pull a 18' center console and i believe mine is a 2 inch drop. 3 is overkill.
  3. Jun 9, 2013 at 2:28 PM
    Tacoma Mike
    Southern Maine
    Drop in your old ball hitch and load everything up as you would going to the lake and start measuring.
  4. Jun 9, 2013 at 3:54 PM
    jbu9136
    13 Prerunner SR5
    My old hitch is a 1 1/4" and won't work in the Class III receiver. I guess I'll try the 2" drop and go from there. Thanks for the info.
  5. Jun 9, 2013 at 3:58 PM
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    I have a 2 inch drop for my 2013 prerunner and it works fine
  6. Jun 9, 2013 at 4:17 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    How about one if these?
  7. Jun 25, 2013 at 8:49 PM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
    Take a measurement from the top of the hitch opening to the ground and take a second measurement from the bottom of the trailer coupler to the ground when the trailer is level.
    The difference between the two measurements is the drop needed.
    http://www.etrailer.com/faq-ballmount.aspx
