Hanging a motorcycle on front
Discussion in 'Towing' started by timburn, Jan 21, 2014.
  1. Jan 21, 2014 at 8:41 AM
    timburn
    timburn [OP] New Member
    Tim
    Pennsylvania
    Tacoma 4x4, access, 6 cl
    Hello folks,
    Pretty new member. I have a friend who carries a motorcycle (Yamaha 225) on front hitch when towing camper on his tundra. I plan on doing same thing on my Tacoma. Bought a Kawasaki KLX250S. curb weight 295. Put the hitch on front. Already own carrier. Test ride waiting for the snow to stop. Any thoughts, concerns,advice?
    Tim
  2. Jan 21, 2014 at 8:47 AM
    Nick82
    Nick82 Well-Known Member
    Nick
    Richmond ky
    2012 DCLB MGM 4x4 sport tow nav
    ARB winch bumper
    I don't think you'll have any problems as long as your front receiver hitch is properly mounted to carry the weight. If it's an occasional haul you'll be fine if you start hauling it often that way you may prematurely wear out your factory springs. In that case you may want to consider some ome springs.
  3. Jan 21, 2014 at 8:49 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There is a member here that was doing the same thing, I can't remember his screen name though. I'd imagine the front would be pretty saggy, if you plan on doing that frequently I'd consider stronger springs but otherwise, I'm sure it'll be fine. That is a lot of stress on the front end so, again if you do it frequently, get ready for things to wear out prematurely.
  4. Jan 23, 2014 at 8:22 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    What hitch are you using brand/model number? pictures?
