4 Cylinder Towing Review (long...)
Discussion in 'Towing' started by Isthatahemi, May 11, 2009.
  1. May 11, 2009 at 7:24 PM
    Isthatahemi
    Isthatahemi [OP] Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    The truck - 2009 Tacoma Access Cab 4X4 SR5 2.7L 5 spd Standard (w/Hopkins agility brake controller)
    The trailer - 2008 Palomino Real Lite 1202 (curb 2100, gross 3200, actual 2400 - 2600 with tank full)
    Before buying this truck, I was surprised that many people believe you need a V6, V8 or a turbo diesel to tow. And the standard response to the question of what can a 4 cyl. tow "not much".
    We towed approximately 250 miles this week, camper weight varied based on water load. As well the truck was well loaded with around 800# of junk, humans and whatnot.
    Acceleration was good, shifting between 4000 - 4500, easily attaining 70 MPH into a 20 MPH headwind. I found 5th gear was doable, CC on, but the engine has an annoying rumble / drone @ 2500rpm. 4th gear and 3000 rpm was quiet and smooth. No sway, ride noticeably firmer, and choppier than normal.
    Turning east the wind was pushing the truck around a little, but no more than usual. 5th gear doable only at almost WOT. 4th gear happy at 70, power to spare....
    Merging and accelerating no problem, (and I'm very impatient). Accelerating to highway speed with other vehicles, no problem. 3rd gear and lots of RPM helped here. On occasion, pushed 3rd to 70mph.
    Into some small hills and curves, required one gear lower than unloaded travel, still no problems...
    Passed a couple vehicles, slower vehicles effortlessly in 4th. Had to run to redline in 3rd once on a tight pass. Pulled back in at 80. No sway, enough power.
    Mileage was tough to gauge. I got 315 miles to a tank, 19.8 gal fill. I usually get 375ish....This tank included 2 hrs of off roading in 4L. Accelerating was mostly 3/4 throttle, 4000 RPM shifts. Not one stretch of road went more than 30 miles between stopping to turn, so lots of accelerating. Pushing headwind or crosswind both ways. (good luck eh?)
    GCWR is 8000#
    Truck 4000
    Cargo 800
    Trailer 2500
    Total 7300
    So after this short trip, I have no doubt that this truck could safely, and capably tow its 3500# rating. (If loaded correctly)
    Kees and rbrionezjr like this.
  2. May 20, 2009 at 6:21 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    nice write up!
  3. May 20, 2009 at 7:13 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Good to know. I don't plan on doing much towing with my 4cyl, but it's good to know I could.
    more like it
  4. May 20, 2009 at 6:06 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    To all reading this:
    Please be advised that the 2008 Palomino Real Lite 1202, is a pop-up camper. I am not insulting the opening poster, his truck, 4-cyl Tacomas in general or pop-up campers. I simply want to put it out there that a pop-up presents SIGNIFICANTLY less drag than a hardside trailer does, and as such pulling the same weight with the added frontal area and air resistance would have lead to a much different write-up. I am not saying that a 4 cyl Tacoma can not pull it's rated 3500lbs, just that mileage, and merging and passing ability will differ from what you just read.
    Regards,
    Adam
    rbrionezjr likes this.
  5. May 21, 2009 at 1:28 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    You'd be slower and use a more gas. Still worth thinking about considering the mileage the vehicle gets when it is in its normal operating mode versus the slowness and lower mileage the few timies it is towing. You pay for the mileage penalty every time you start it up with the 6.
  6. May 25, 2009 at 3:03 PM
    Isthatahemi
    TRD OFF ROAD
    My experience has been that the mileage drop towing with a 4 cylinder is greater. But that the mileage is still better than a larger engine,, just not a lot better. However, I would have to see proof that a V6 would get better mileage in any circumstance. The 4 cylinder has lower Brake Specific Fuel Consumption across it's entire powerband vs the 6. So theoretically, it's not possible....
  7. May 29, 2009 at 4:36 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Thanks for the info! I really appreciate it, and it helped me find out what my Tacoma was really capable of.
  8. May 29, 2009 at 4:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, I get about 15 to 17 when towing my boat 40/60 city/hwy. Boat weight is 2989 lbs. not includeing gear. Last trip out, I got 17.44 mpg.
    Hope this helps. :)
  9. Jun 10, 2009 at 1:57 AM
    scrapedface
    scrapedface Well-Known Member
    vacaville, ca
    2008 2.7 liter 4wd tacoma
    ipod charger and aux cable, scanguage 2, wet okole seat covers, 35% tint, toytec ultimate set at 2.5"
    i towed 2800lbs with my manual 2.7l 4x4 2008 accross country. no problems. drove over colorado reaching 11500ft at one point. did well at altitude. going over mountains didn't really affect my gas mileage cuz it made up for it going down hills. i saw 19.8 to 22.3 mpg average. worst mileage being going across kansas from east to west. slight uphill the entire way and 50mph cross winds. truck was real sluggish then. some inclines i was in second gear screaming at 35mph uphill. i had no brakes on my trailer so going downhill from utah was a little scary. i kept it in 3rd gear and was constatnly on the breakes trying not to exceed 55mph.
  10. Jun 10, 2009 at 3:11 AM
    bryanc
    bryanc Well-Known Member
    ottawa ontario canada
    09 access 4cyl 2wd
    home made diamond tonneau with flip up and canoe racks
    Just read your results and very nice, thanks for the info. I have a 09 acces 4cyl auto and a Palamino Pony. Camper at 1600 lbs, and Taco (Alu tonneau cover and canoe over tonneau) cargo at 6oo-65o lbs. Have only completed two trips so far and at 24 mpg Canadian, I did expect better. I do not use OD but maybe on the flats I will try it, and I do not drive over 60mph towing. However the Taco handles all requirements nicely. 4 cyl Taco is a nice truck and I couldn't want more.
  11. Jun 10, 2009 at 3:54 PM
    Isthatahemi
    TRD OFF ROAD
    24 MPG cdn. is incredible mileage. I would be absolutly amazed if I was getting that, dragging around the load you described, very cool. Are you sure that is correct? That's less than 12L / 100kms!
  12. Jun 11, 2009 at 6:53 AM
    bryanc
    09 access 4cyl 2wd
    Hi....Scrapedface...
    Your stats for towing appear to be very close to what I got for my mpg Canadian, meaning we are getting very close to the same mileage. I had about 2300 Lbs total cargo and trailer and same mph driving. I think that is right?
    Thanks for stats.
    BryanC
  13. Jan 2, 2010 at 7:45 PM
    Isthatahemi
    TRD OFF ROAD
    Back from the dead....
    There was a comment made that the 4 cyl will get worse mileage than the V6 when towing.
    NOT SO.
    My V6 mileage doesn't even compare to the mileage I got from the 4 cyl, any load, any speed, ever. I will post more exact #'s after I have done more towing with my 2010.... So far, I would say the V6 gets approximatly 2 - 3 mpg less consistantly. If Toyota ever sells a 4cyl 4X4 auto, I will buy one.
  14. Jan 2, 2010 at 8:04 PM
    MotoXFreeStyle61
    MotoXFreeStyle61 Displaced Texan
    San Antonio TX
    06 PreRunner SR5 4Cyl, Access Cab, 5
    Black Head Light Mod, Tacoma All Weather Mats, ScanGauge II, Tonnaeu Bed Cover, 40% Tint, Added Fog Lights, 600W x 1 Alpine MRP-M650 Amp, Alpine 10" Type-R SWR-1022D Sub, Secondary Air Filter Removed, Day Time Running Lights, K&N Drop In Air Filter (oiled), Westin Bullbar (Black Powder), Alpine IVA-W505 w/Nav, JL Audio 6.5" Front Speakers, Toyota SR5 Seat Covers, 2.5" Toytec Spacer
    Just for my FYI: Where did you get the info on the Brake Specific Fuel Consumption for our vehicles?
  15. Jan 4, 2010 at 3:42 PM
    Isthatahemi
    TRD OFF ROAD
    All else being equal, BSFC is lower on a smaller engine, or one with fewer cylinders, until more than 90% load is applied, as a rule of thumb. And the 2TR has advantages with it's valve timing and cam phasing sophistication over the 1GR.I don't have BSFC info for these two engines. I have pratical towing data from my calibrated scanguage, from 18000 kms on my 2009 4cyl 4X4, And now from 9000 kms on my 2010 V6 OR. The basic idea I was conveying, is that I have not encountered a circumstance, loaded or unloaded, where the mileage is even comparable. Same driver, same speeds, same load, same circumstances.
  16. Jan 4, 2010 at 3:53 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    you'd get alot better mileage if you changed gears around 2500-3000 rpms
  17. Jan 4, 2010 at 8:09 PM
    Isthatahemi
    TRD OFF ROAD
    Thats just too damn slow with 2700# of trailer, and 900# of people and gear.
  18. Jan 21, 2010 at 6:36 PM
    austex
    austex Member
    Tom
    Texas
    Base
    How do you lock out OD on an auto? I have the same truck you do.
  19. Jan 22, 2010 at 4:28 AM
    bryanc
    09 access 4cyl 2wd
    Good morning Austex...
    I drive the truck in 3rd. That's it. When towing. When using the truck non tow I drive in 3rd and slide the shifter to D when ever the speed hits 90km per hour. I treat it the same as I would my 5speed std transmission in my Subaru or Corolla. I found with this transmission that if I just drive in D the trans will shift at around 80 83 kmph. I can feel that the engine seems to lug a little. I don't like to be in D less than 1800-2000 rpm. I think 3rd final drive is 1.0 and 0.705 for 4th OD. My Canadian mpg now here in winter at speeds mostly 60mph is 25/26 mpg. I am not getting mpg I thought I would with this truck but I love this truck a whole big bunch all the same.
    Bryanc
  20. Jan 22, 2010 at 4:46 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Please remember that a Canadian gallon is approximately 1.21 US gallons. Therefore MPG for Canada will be higher than US MPG. 2nd Gen Taco Fuel Capacity is 21 US gallons (or 17.48615 Canadian gallons).
    Perhaps that will help those confused by the higher MPG achieved by Taco drivers in Canada........
