Go Back   Tacoma World Forums > Tacoma Discussion > Toyota Trucks & SUVs
3" lift questions
Old 02-09-2012, 04:37 PM   #1
tacofan09 [OP] tacofan09 is offline
tacofan09 is on a distinguished road
tacofan09's Tacoma Gallery
3" lift questions
I have an 2009 Double Cab TRD 4x4 tacoma, The susp. is all factory, I'm looking to install a 3" susp lift. My question is, do I need to change the rear factory Bilstein shocks if I add a 3" spacer under the rear springs? I also have 265/75/16 tires would this look okay with the 3" susp. Lift.?? Just wondering
Old 02-09-2012, 04:39 PM   #2
Pineapples on pizza Hawaiian does not it make.
Konaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shed
Konaborne's Avatar
Konaborne's Tacoma Gallery
there's tons of people running that size with 3" lifts. its all a matter of personal preference.
You will need to change your rear shocks, stock are too short
Old 02-09-2012, 04:39 PM   #3
Nom Nom Nom
05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed
05RedTaco's Avatar
05RedTaco's Tacoma Gallery
I run 2" AAL with factory shocks in the rear. Its OK, however you wont have as much flex in the rear while off roading.
Old 02-09-2012, 04:40 PM   #4
ColtsTRD's Avatar
ColtsTRD's Tacoma Gallery
I have a 3" lift with 265s...see my sig. Will be running 285s soon though
2" AAL with Bilstein 5100s for the rear.
Old 02-09-2012, 05:08 PM   #5
Bush Pusher
Hairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shedHairy Taco is one of the sharper tools in the shed
Hairy Taco's Avatar
Hairy Taco's Tacoma Gallery
You referring to a 3" block for the rear? You sure you want a block that thick? If yes, then consider a longer shock.
Old 02-10-2012, 08:39 PM   #6
3" Lift Questions on Tacoma
Thanks for the reply's back... ...
Old 02-10-2012, 09:13 PM   #7
a 3" lift, does it make the truck sit level.? 3" in front and 2" in rear?
and still use my stock rear Shocks?
Old 02-11-2012, 04:07 PM   #8
Nom Nom Nom
05RedTaco's Avatar
I have 3" spacers up front and 2" AAL in the rear, my truck is almost level with very slight rake, almost not noticeable. Stock shocks in the rear...
Old 02-16-2012, 09:00 PM   #9
does any one know if you need to install a diff spacer when you install a 2" spacer on the top of the front shocks,? 09 TRD Tacoma
Noob questions about 33"s on stock 15x7 rims, with 2.5" lift woodpost Wheels & Tires 3 09-07-2011 03:03 PM
3" Lift Questions dman597 2nd Gen. Tacomas 11 01-29-2010 03:54 PM
3" lift questions! DEFsTACO Suspension 5 02-05-2009 12:59 PM
3" lift questions spadresurfer91 2nd Gen. Tacomas 6 11-16-2008 07:52 PM
3" Lift Questions luk8272 Suspension 13 03-06-2008 08:40 PM
