#1 |
1998 tacoma remote start need help
hi i bought a remote start, hood up for my 1998 tacoma . i hook everything
up except the purple wire ENGINE SENSING WIRE. i have no idea where that wire go. i got it start, engine running for a few second and it shut off and restart again, over and over. on the start relay with yellow wire hook up to the (black ) start wire . onthe sketch. do i have to hook up the the alternator. if yes which wire to the alternator please help SENS.PDF |
#2 |
Waiting on new tune!
Thats wierd. Sorry im no help, but WTF is the engine sensing wire!!
#3 |
Tacoma Newbie
sounds like the tach wire. the remote start needs a tach signal to know its running. some remote start units can be programmed for voltage sensing without needing a tach sensor wire. if yours can't do that, you'll have to hook the tach sensor wire up - usually under the hood. i dont know which wire that would be but i usually get that info from 12volt.com
#4 |
how about the relay wire in sketch , yellow wire for the relay go to start
wire and it also show connect to the alternator. do i have to hook that wire up. what the purpose for that wire hook up the the alternator . if yes please advise thanx you |
#5 |
need help please, i found the tachometer wire test it have 4 volt .
bought a tach fr autozone hook it up and it good reading the rpm ok. however. when i hook the up the engines sensing ( on my fist post see sketch pdf). i stilll have same problem the engine is start after the running for 5 second it shut of and restart again please help. |
| Display Modes | |
| Remote Start | stucksucksnayota | 1st Gen. Tacomas | 5 | 04-22-2008 06:13 PM |
| 2001 Tacoma Remote start help | hoxie08 | 1st Gen. Tacomas | 2 | 03-13-2008 03:02 PM |
| remote start | dsds | 2nd Gen. Tacomas | 8 | 03-08-2008 09:54 PM |
| Remote start | Bfmco7 | 2nd Gen. Tacomas | 16 | 01-10-2008 11:07 PM |
| 2007 tacoma remote start | chuck8ch | 2nd Gen. Tacomas | 1 | 12-29-2007 06:54 PM |
