Go Back   Tacoma World Forums > Tacoma Discussion > Toyota Trucks & SUVs
2nd gen HILUX bed/grill questions
Old 10-11-2012, 10:44 PM   #1
MrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shedMrGuitarguy is one of the sharper tools in the shed
MrGuitarguy's Tacoma Gallery
So lately Ive been on this rat rod obsession. I really wanted to get a stout and do the whole white wall red rim drop thing, but parts are going to be an issue.
I'm a big fan of old toyota trucks, specifically the 1st and 2nd Gen HILUX's. Ive been googling a lot of them and noticed a few things. I was hoping you guys could answer my questions:
1) If you look at the beds of a stock hilux, and some of these modded hilux's, youll see that the stock beds are not level with the cab. Does one have to modify the bed, or fabricate a custom bed in order to level it with the cab like these custom hilux's, or is a frame/bed adjustment?
2) If you notice the grills, some have different grills. If you look at this flickr example the lights have a sort of housing around them. The grill is not as open, or solid. It doesnt look like one piece unlike the other pictures. Are they different front ends, or is this housing just taken off.
http://www.flickr.com/photos/mr38/64...n/photostream/
Old 10-11-2012, 10:50 PM   #2
Rich91710's Avatar
Rich91710's Tacoma Gallery
Not sure what you're referring to.
On the bed, they are both the same, but on the slammed truck, the cab has been cut... the rocker panel and everything below the edge of the door has been cut off, which makes it more level with the bed bottom.
On the grille, other than what might be some custom chrome, I'm not seeing a difference. The original truck had basic black headlight surrounds.
Old 10-11-2012, 10:58 PM   #3
Okay, the original truck has a smaller grill. If you look at the space it is smaller than on the modified trucks. The modified trucks have an open "solid" looking grill, (Similar to a 69 charger). The flickr picture has a smaller length.
Also thanks for answering my question about the bed. It was the rocker panels. That was puzzling me. How much would it cost to cut them off and slam the truck.
Old 10-11-2012, 11:02 PM   #4
Rich91710's Avatar
Same grille... camera angle and the lack of apparent chrome makes it look different.
Count the horizontal bars... 7 on both grilles, and it's the same logo.
Old 10-11-2012, 11:09 PM   #5
The stock hilux has that yellow thick bar (or surround, its been a long day. Its hard to describe it. The lights are surrounded by the grill, while the custom trucks are not) on the side of the lights, the custom ones do not. Can you take it off? Or do you have to cut it off?
Also you got rep. So I appreciate your time.
Old 10-11-2012, 11:14 PM   #6
Rich91710's Avatar
Oh, the surround?
I'm pretty sure it's the same. Again, camera angles make it look different, as well as the dull primer color.
The adjustment holes under the headlights are still there in the same position.
The yellow lights under the bumper are the turn signal, and market lights on the fender... both legally required.
Old 10-11-2012, 11:32 PM   #7
Oh, the surround?
There. I dont think its the angle. Its a smaller grill and the lights are surrounded unlike the custom hilux's. The lights are enclosed on on this one.
Old 10-11-2012, 11:39 PM   #8
Rich91710's Avatar
Ahh... that wasn't in the original post.
Different year.
Like the 2012/2011/2009, there are styling differences even in the same "generation".
Mid-80s trucks were all over the place on the bed... some had hooks, some didn't, some had two "latches" on the tailgate, others had the center handle.
Old 10-11-2012, 11:44 PM   #9
Rich91710's Avatar
Ya... '72-'78 for that generation, n the US the 2.0 (18R) ran in '73 and '74, then they went to the 20R 2.2l in '75.
You're likely comparing a '75-'78 against a '74 or older.
Old 10-11-2012, 11:47 PM   #10
So the 72 to what had the longer grill without the enclosed lights?
Also thanks man. Ive been googling away on these grills.
Old 10-11-2012, 11:49 PM   #11
Rich91710's Avatar
More likely, the more open grille is the newer model.
Datsun did the same thing. I had a '76 Datsun pickup and it was open like that.
Old 10-12-2012, 12:01 AM   #12
Thanks for all your help. Is it hard finding parts for the old hilux's or are they easy because they were mass produced?
Old 10-12-2012, 12:29 AM   #13
Rich91710's Avatar
Pretty tricky finding parts for anything from more than 15-20 years ago.
They were mass produced, but the first couple of generations were not imported in huge numbers. I mean, there were a lot of them on the road, along with the Ford Courier and Chevy LUV, but the imports were still battling hard to grab the US market.
It wasn't until our 2nd large increase in fuel prices in 1980 that Toyota and Nissan took a solid hold on the market.
2nd Gen Truck Bed Bolts questions jtnyc Technical Chat 9 10-02-2012 01:40 PM
Pics of 1st Gen shell on 2nd Gen DC Short Bed Comanator 2nd Gen. Tacomas 18 01-29-2012 12:01 PM
Wanted: Bed Mat for 2nd Gen long bed Tim A Buy / Sell / Trade 2 01-10-2011 09:58 PM
WTB: Tonneau Bed cover in SOCAL for a 2nd Gen double cab short bed kalib0y Buy / Sell / Trade 0 05-04-2010 01:45 PM
2nd Gen Tacoma bed size vs. Hilux Bed size? boks 2nd Gen. Tacomas 14 03-01-2010 06:53 PM
