Go Back   Tacoma World Forums > Tacoma Discussion > Toyota Trucks & SUVs
1998 tacoma p/u won't start after getting hot
Old 09-23-2013, 09:05 AM   #1
Gunboat [OP] Gunboat is offline
Gunboat is on a distinguished road
Gunboat's Tacoma Gallery
My friend has a 98 tacoms p/c 16 valve,4 cylinder 4 wheel drive.After driving it and it gets to operating temp,and he turns it off,it refuses to start back up until it cools back down...then it starts and runs fine...anyone have any suggestions on what to look for? Also,plugged in the reader to the OBD and it said that the engine was running lean,no other trouble codes came out...the engine cranks over just fine it's getting fire and fuel,new plugs..
Old 10-09-2013, 07:56 AM   #2
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
Plenty of suspects to check out.
O2 sensors
temp sensors
fuel pressure reg
Old 10-10-2013, 04:16 AM   #3
thanks for the reply...I have read numerous posts on this and they say just about the same thing that you have mentioned,thanks again for the reply..
Old 10-31-2013, 01:45 PM   #4
Konvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shedKonvict KROG is one of the sharper tools in the shed
Konvict KROG's Avatar
Army: 31b and 29e
Konvict KROG's Tacoma Gallery
fuel delivery issue, like mentioned above
or possibly only enough fuel to run while still on cold start injector? if there was crud in the fuel system the filter does not always get it and it can still plug up your injector's
Old 10-31-2013, 04:27 PM   #5
3RZ Taco is a jewel in the rough3RZ Taco is a jewel in the rough3RZ Taco is a jewel in the rough
3RZ Taco's Avatar
Army: 91B Wheeled Vehicle Mechanic
3RZ Taco's Tacoma Gallery
Try replacing the fuel cap, my 96 would run fine all day until night time and wouldnt not start unless i fulled the cap off and let the air pressure out of the tank. Searched and searched for what could be the problem, spent 15$ on a new locking gas cap and havnt had the problem since.
Old 10-31-2013, 06:35 PM   #6
92yotapu is on a distinguished road
92yotapu's Avatar
Marines: veteran corporal, mike battery 3rd battalion, 11th marines
92yotapu's Tacoma Gallery
For your issue check the vent solenoid on your evap canister it night be plugged
Old 10-31-2013, 06:41 PM   #7
92yotapu's Avatar
Check fuel pressure at cold start and while running warm shouldn't be a major difference and while its running hot pull fuel cap if it hisses like is sucking in air you have a bad tank vent
Truck won't start after doing the 12v plug always hot mod. Danimal69361 Technical Chat 28 07-23-2013 07:05 AM
07 Tacoma Won't Start After Running In Hot Weather brodave 2nd Gen. Tacomas 3 06-03-2012 05:20 PM
1998 TACO WON'T START/ CHECKED EVERYTHING smagohawks 1st Gen. Tacomas 9 09-01-2011 03:56 PM
Starter gets too hot, won't start? fishsticks 1st Gen. Tacomas 16 03-12-2011 11:21 AM
1998 tacoma remote start need help CVLVNB Toyota Trucks & SUVs 4 12-13-2008 12:24 PM
