Go Back   Tacoma World Forums > Tacoma Discussion > Toyota Trucks & SUVs
92 electrical?
Old 06-22-2010, 05:04 PM   #1
92taco [OP] 92taco is offline
92taco is on a distinguished road
92taco's Tacoma Gallery
92 electrical?
i have a 92 tacoma that had been sitting for 6 years but she runs "great" now. however when i use my blinker (not as often as i should ) the needle on the speedo drops and then returns any thoughts? it has the 3.0 v6 and is 4x4 if that helps
Old 06-22-2010, 05:16 PM   #2
Trap is one of the sharper tools in the shedTrap is one of the sharper tools in the shedTrap is one of the sharper tools in the shedTrap is one of the sharper tools in the shedTrap is one of the sharper tools in the shedTrap is one of the sharper tools in the shedTrap is one of the sharper tools in the shedTrap is one of the sharper tools in the shedTrap is one of the sharper tools in the shedTrap is one of the sharper tools in the shedTrap is one of the sharper tools in the shed
Trap's Avatar
Trap's Tacoma Gallery
The blinker lights might be dragging down the voltage on the circuit.
I'd pop all the lights open and check them for corrosion then apply some grease before you buckle them back up again. Check the visible wiring that you can see when you have them apart. If you have them open might as well check all the bulb sockets while your at it.
If it's a semi short is in the steering column it's going to be a pain to fix. Could be a bad ground also. Maybe one other thing to check is the blinker relay. Make sure you have the electronic type and not the heating element type. How to tell? You usually can't see inside the heating element type. The electronic ones are or look like a relay that you can see inside them threw the green or clear cover.
92 P/U no start crashradius Toyota Trucks & SUVs 3 10-15-2011 03:39 PM
92 pickup help 92taco Technical Chat 4 06-21-2010 01:42 PM
92 4-Runner gonzo6up General Automotive 0 03-12-2009 10:37 AM
Ufc 92 Motoknuckle Sports, Hobbies & Interests 8 12-28-2008 08:24 AM
gas, 92 octane? fce18 2nd Gen. Tacomas 27 12-01-2007 01:04 PM
