hauling 4x8 sheet rock
Discussion in 'Toyota Trucks & SUVs' started by mrdinh, Feb 14, 2011.
  1. Feb 14, 2011 at 10:20 AM
    mrdinh
    mrdinh [OP] Active Member
    TRD SR5
    westin nerf bars and argricover soft roll up bed cover
    how to? the bed is not 4ft wide...standing the sheet rock panels would not be a good idea right?..they are fragile...any ideas?
  2. Feb 14, 2011 at 10:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    I used to purchase two 2x4's, lay them down with the tailgate up about 3 ft apart and all the way to the front, then lay the sheet rock on them.
    Or you can buy a bigger truck :D
  3. Feb 14, 2011 at 10:23 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Stick two 2x4s and angle up on the tailgate
    EDIT: ahhh beat me to it
  4. Feb 14, 2011 at 10:24 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Yup, 2x4's or rent a trailer for an hour or two but as long as you aren't hauling a ton of sheetrock the 2x4s work well.
  5. Feb 14, 2011 at 10:24 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Feb 14, 2011 at 10:24 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    I fit a 4x8 sheet of MDF in mine. just put something under the middle of the rock so it don't break in half.
  7. Feb 14, 2011 at 10:26 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This , or if you look at the bedsides , there are two approx 1" deep x 7" depressions at a height about the same as the top of the wheel wells .
    Cut a 2x4 or 2x6 to fit side to side and put one in the front depression , rest the back of the drywall on the tailgate .
  8. Feb 14, 2011 at 10:28 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I've hauled 4X12 sheet rock in my truck. Just put two 2X4's the length of your sheet rock riding on the tailgate and drive at speeds where it doesn't bounce to crazy.
  9. Feb 14, 2011 at 10:37 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
  10. Feb 14, 2011 at 10:45 AM
    OZ-T
    Peter North
    British Columbia
    I just realized the front depression might be a longbed only thing , not sure if there is one on a short bed .
  11. Feb 14, 2011 at 10:46 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    SB has it too
    there's also a depression toward the back, on top of the cubbies
  12. Feb 14, 2011 at 10:52 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just put them over the wheel wells and have some center support. I have hauled a 4x12 sheet of drywall in my shortbed before.
    I put 4x8 sheets of plywood in there all the time.
  13. Feb 15, 2011 at 5:32 PM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    I used wheel wells plus a few cinder blocks in middle for support...took it easy on the way home
  14. Feb 15, 2011 at 5:36 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    Nuh uh
  15. Feb 15, 2011 at 5:38 PM
    OZ-T
    Peter North
    British Columbia
    5' in and 7' out ?
    How dat work ? You must have had some shorter sheets on top ?
  16. Feb 16, 2011 at 6:51 AM
    macgyver
    Brad
    Canton, GA
    With the tailgate down you get about 6' and some change. I had some 12' 2x4's underneath that were strapped down in the front to my front D-rings to give it some support plus some ratchet straps hooked to the tailgate latches. I only had to go about 1.5 miles. I was putting in an 11' long knee/pony wall and wanted to limit my mudding and taping :D.
  17. Jan 9, 2018 at 6:41 PM
    correct carry
    correct carry Member
    A solution to your hauling needs is coming soon. We've started a company to address this problem and will be in production soon. www.correctcarry.com is the site and we expect to be in production by mid February.
