-   Toyota Trucks & SUVs (http://www.tacomaworld.com/forum/toyota-trucks-suvs/)
-   -   3" lift questions (http://www.tacomaworld.com/forum/toyota-trucks-suvs/203454-3-lift-questions.html)
tacofan09 02-09-2012 04:37 PM
3" lift questions
I have an 2009 Double Cab TRD 4x4 tacoma, The susp. is all factory, I'm looking to install a 3" susp lift. My question is, do I need to change the rear factory Bilstein shocks if I add a 3" spacer under the rear springs? I also have 265/75/16 tires would this look okay with the 3" susp. Lift.?? Just wondering
Konaborne 02-09-2012 04:39 PM
there's tons of people running that size with 3" lifts. its all a matter of personal preference.
You will need to change your rear shocks, stock are too short
05RedTaco 02-09-2012 04:39 PM
I run 2" AAL with factory shocks in the rear. Its OK, however you wont have as much flex in the rear while off roading.
ColtsTRD 02-09-2012 04:40 PM
I have a 3" lift with 265s...see my sig. Will be running 285s soon though :)
2" AAL with Bilstein 5100s for the rear.
Hairy Taco 02-09-2012 05:08 PM
You referring to a 3" block for the rear? You sure you want a block that thick? If yes, then consider a longer shock.
tacofan09 02-10-2012 08:39 PM
3" Lift Questions on Tacoma
Thanks for the reply's back... ...
tacofan09 02-10-2012 09:13 PM
a 3" lift, does it make the truck sit level.? 3" in front and 2" in rear?
and still use my stock rear Shocks?
05RedTaco 02-11-2012 04:07 PM
I have 3" spacers up front and 2" AAL in the rear, my truck is almost level with very slight rake, almost not noticeable. Stock shocks in the rear...
tacofan09 02-16-2012 09:00 PM
does any one know if you need to install a diff spacer when you install a 2" spacer on the top of the front shocks,? 09 TRD Tacoma
