-   Toyota Trucks & SUVs (http://www.tacomaworld.com/forum/toyota-trucks-suvs/)
-   -   1996 tacoma 2.7 runs rough (http://www.tacomaworld.com/forum/toyota-trucks-suvs/246164-1996-tacoma-2-7-runs-rough.html)
toyotaman4ever 10-28-2012 01:50 PM
i picked up 1996 tacoma 4x4 ext cab runs rough code 0340 put in new distributor,maf hardly starts misfires took off air box system sprayed choke cleaner thru system got it running and idling put together still running till i plug in maf kills engine any help similiar problems fixed?
mac424205 10-28-2012 05:49 PM
might need a new maf sensor
toyotaman4ever 10-28-2012 07:43 PM
put new maf in same problem
mitchellayes 10-29-2012 07:54 PM
Might just be a bad spark plug wire...Might be running on 5 cylinders due to this. CHeck all your wires to make sure they are in all the way!
http://www.tacomaworld.com/gallery/d..._with_20_s.jpg
mac424205 10-29-2012 08:28 PM
2.7 is a 4 cyl. The truck wouldn't cut off when the MAF was plugged in if it was a bad wire. It would mis like crazy
