-   ToyTec Lifts (http://www.tacomaworld.com/forum/toytec-lifts/)
-   -   small lift for 2011 Tacoma Dbl Cab 4x4 (http://www.tacomaworld.com/forum/toytec-lifts/163231-small-lift-2011-tacoma-dbl-cab-4x4.html)
nmhs 06-21-2011 04:15 PM
Hello,
I am the owner of a 2011 tacoma SR5 dbl cab 4x4 and I would like to give it a small lift. I need around an 1.5 to 2 inches of clearance since I cut firewood. I wont use it for any kind of four wheel driving except for a few days of firewood cutting.
I have looked at all the options for toytec and I was wondering what everyone recommends.
Thanks,
whippersnapper02 06-21-2011 04:19 PM
5100s for the front. Search.
stunt man hans 06-21-2011 04:21 PM
wow.... welcome from nj.
nmhs 06-21-2011 05:42 PM
Thanks, I was told that I should look at the toytec 3 inch blocks and a 1.5 inch block in the rear. This seems to be a little harsh for what I might be looking for. What do you think?
thanks!
Quad D 06-21-2011 07:08 PM
I've got the same truck, and am in the same position. I only need a small lift for now. Actually to clear the speed bumps in my neighborhood. I had no idea the 2011 4x4 dbl cab sat so low. :(
OZ-T 06-21-2011 08:03 PM
Cut 1 1/2" of your mudflaps
Quad D 06-21-2011 08:08 PM
I'm serious, these are some steep speed bumps. It's metal scraping, without a doubt, just as the front tires pass, no issue in the rear. Really don't want to jack the thread though. I'll do some more searching and start my own thread.
TacoBS 06-21-2011 08:44 PM
Originally Posted by nmhs (Post 3339899)
Hello,
Thanks,
I was also in the same boat w/ my DCLB 4x4. I couldn't afford a fancy lift and wanted to maintain the stock feel for the first year or two, but needed something to help prevent the bottoming out at one of my favorite hiding spots. I went with a 2" spacer up front and a 1" block in the back.
Super happy with the results for now. No more bottoming out or scraping mudflaps, all with a nice stock feel...and installed for well under $3 bills. It's nice cause it is functional for what I do, as I won't be wheeling too crazy just yet in my brand new truck...cost way too damn much money for that right now.
This is not the end goal, however. A year or two down the road I will graduate to some 3" coils and a new leaf pack. Just trying to save for that...so the real fun can begin.
Here's how it looks with the spacer/block set up.
Hope this helps your decision either way.
http://www.tacomaworld.com/gallery/d.../aIMG_2676.jpg
http://www.tacomaworld.com/gallery/d.../aIMG_2632.jpg
OZ-T 06-21-2011 08:47 PM
I got 2 1/2" front and 2 3/4" rear with the OME kit , 885's no spacer and Dakars
http://www.tacomaworld.com/gallery/d...liveGcLex5.jpg
nmhs 06-23-2011 05:46 AM
Thats exactly what I'm looking for. Which spacers did you use?
nmhs 06-23-2011 05:47 AM
Are you talking about spacers or springs? What is the OME and 885s?
Zombie Runner 06-23-2011 06:03 AM
springs. OME is old man emu. they make great springs. 885 is the spring number. for our trucks they have 884, 885, and 886.
for a double cab taco with stock front bumper you would want to probably go with the 885's. factory shocks will not do well with these so you would need to upgrade to the bilstein 5100's or the OME nitro shocks. the toytec site sells all this stuff. also check out wheelersoffroad.com
the cheapest / most effective route you could take would be to just get the billstein 5100 shocks and set them at the 1.75" setting to lift the front so that it would be level with the rear. since you said you will be hauling firewood I would reccomend getting an AAL (add a leaf) for the rear. this will lift the back 1.5" and allow you to carry a little more payload.
Zombie Runner 06-23-2011 06:09 AM
for what you are wanting the lift for blocks will not do you well.
for just a few more dollars you can get much better parts by going with an AAL for the rear and upgrading either shocks or springs and shocks forthe front.
5100's for the front. its wise to get them for the rear too but you can always add them later if you cant afford them now
http://www.wheelersoffroad.com/05uptacoadjbils.htm
for the rear lift. ive had both the 1.5" single AAL and the 1.5" 3 leaf pack, I love the ride and feel of the 3 pack.
http://www.wheelersoffroad.com/05uptacoaal.htm
nmhs 06-23-2011 08:21 AM
What size tires are you running with this setup?
Thanks!
nmhs 06-23-2011 08:26 AM
Thanks for the info. If I go with the AAL for the rear will I need to raise the front more that 1.75? What are the differences between the front shocks and the spacers? I really like the idea of a better payload so I will probably go with a rear AAL. With this type of set up what size tires would you recommend? Once again, thanks for the info.
pudge151 06-23-2011 08:33 AM
you really wont gain any clearance unless you put on taller tires, in which case you will need more lift
Zombie Runner 06-23-2011 08:50 AM
well do you want your truck to sit level without a load or sit level with a load? a 1.75" in the front and a 1.5" in the rear will pretty much keep the same stance as it has now, but just taller all around.
spacers and the 5100's basically do the same thing by preloading your springs. the 5100's just do it better by giving you better shocks giving you a better ride.
why wouldnt he gain ground clearance? he wont gain any under the rear diff but thats about it...the frame and undercairage will sit up higher
TacoBS 06-23-2011 09:06 AM
Thanks!
I have a 2" in the front and 1" in the back that was machined locally here in San Luis Obispo. I have their info if you are around here. You would probably get the same results from any setup of similar size from Toytec, etc.
Again, this is a temporary setup to fix an immediate problem...and the only thing I could really afford at the time. I also like how it maintained everything to as close to stock as possible (for the time being.)
In truth, the setup that zombie describes would be more ideal for a little more money, and I would have gone that route too, but a "little" more money might as well have been a lot more in my case. And it maintained the stock feel that I was looking for.
Oh and the tires are just the crappy stock dunlops at 265/65/17. Want to wear 'em out a bit, 'ya know.
nmhs 06-23-2011 02:55 PM
Thanks for all the advice. I will mull it over come back with some more questions.
2010Tacoma4x4 06-23-2011 03:16 PM
I did the same in the front as others have suggested with the 5100's. I had the rear leaf TSB installed by the dealer which upgraded the factory 3 leaf spring to a 4 leaf.
I went ahead and purchased the 5100 4 shock package from "Downsouth" '''they were the best price when I was shopping. They are set @ 1.75
Downsouth Motorsports - Click Here
After the lift I was able to fit a 265/75/R16 (31.5 x 10.5) tire with no rubbing and the truck sits nice and level when towing my boat. I am really happy with the way it rides....drives straight with no vibrations. Installing the 5100's did require an alignment afterwards.
