-   ToyTec Lifts (http://www.tacomaworld.com/forum/toytec-lifts/)
-   -   OME lift- Top plate spacers question (http://www.tacomaworld.com/forum/toytec-lifts/206507-ome-lift-top-plate-spacers-question.html)
Designated Hitter 02-25-2012 06:55 PM
I'm about to order the OME lift kit. I want to do the top plate spacers with it. My questions are:
  • What size spacers are these?
  • Will these account for the taco lean or do I need to get the trim packer in addition to the spacers?
  • With the 2" aal will I be level or close to nose high?
I prefer level to a bit nose high rather than tail-end high. Will this get it done?
2011 trd sport double cab short bed 4x4.
Thank you for any input
Janster 02-26-2012 04:14 AM
You need to tell us what OME coils you are referring to.....
There are many different types.
Generally, it's NOT a good idea to run lift coils & spacers together.
Get the proper amount of lift that you need in the coils - and you won't need spacers.
Twistedfreedom 02-26-2012 04:21 AM
Skip the top plates but do get the 5mm Taco lean shim
Designated Hitter 02-26-2012 11:48 AM
885 coils, sorry
Twistedfreedom 02-26-2012 11:51 AM
I'm on 885x just get the 5m taco lean shim and you'll be fine unless you plan on adding a plate bumper then get the 886x and if you want the Bro lean get the 1.5" AAL instead of the 2"
OZ-T 02-26-2012 12:06 PM
The 5mm trim packer for taco lean only works if you are getting OME shocks too .
Twistedfreedom 02-26-2012 12:08 PM
There ya go :cool:
OZ-T 02-26-2012 01:32 PM
There ya go :cool:
Some people people get the OME coils and 5100's and say they have an " OME lift "
Just clarifying
Designated Hitter 02-27-2012 10:16 PM
Can I get the 1.5" aal w/out having the rear tsb?
Twistedfreedom 02-27-2012 10:21 PM
you can get them no problem the back of your truck will be about level with the front.
