Go Back   Tacoma World Forums > Shopping > Vendor Reviews
LSK Suspension Burbank, CA
Old 12-19-2012, 08:52 AM   #1
Hiatt1991 [OP] Hiatt1991 is online now
Hiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shed
Hiatt1991's Avatar
Hiatt1991's Tacoma Gallery
Send a message via MSN to Hiatt1991
Hi guys. As many of you already know, I recently decided to pull the trigger on a longtravel kit. At the time, I had enough for the Camburg kit that I wanted but after thinking about it, I wanted something different. I then approached LSK here on the forums about doing a prototype kit for my 2nd gen. They automatically accepted the challenge. Seeing these guys work is pretty incredible. Most of these guys are younger college students but don't let that fool you. They are extremely familiar with doing suspension work and everything that goes into designing like stress tests, full CAD drawings, ect. Overall, I would do it all over again. They designed my kit, plasma cut all the pieces out, welded everything together, hand machined the steering extensions, bolted on the kit, cycled it (to get the travel numbers), aligned it and had me out driving it in less than a week. They also had AMAZING customer service. They always let me come down and check on the progress of the kit and always listened to my opinions or questions about the kit. The steering extensions took a little longer then we thought to make so they offered to deliver my truck all the way from Burbank to my house in Walnut (30 miles) when they were finished test driving it to make sure everything was working properly. They had no hiccups when putting this together. It all seemed to come together flawlessly. The fitment on the lowers and uppers was superb. No hitting or bashing required. They literally fit like a glove! Steering feels tight and its easy to drive with one hand! Im extremely happy with the outcome of this kit! These kits will be built per request and are ready to order! Contact LSK for pricing!
http://www.lsksuspension.com/
The 2005-Current Toyota Tacoma LSK long travel kit is 3.5" wider than stock and utilizes fully hiemed upper control arms and a 1" uniball. The lower arms use Delrin bushings and are bolted to a 1" lower uniball. The kit itself is made out of 3/16" inch steel while the bottom is made out of 1/4" steel. It is fully mig welded together on all sides. The lower cam tab bolts have been eliminated and instead use boxed spacers so you will never need to worry about having a mechanic align your truck. The bushing sleeves and upper control arms are constructed out of DOM round bar so there is no seam that can fail. It can all be done at home with a jack and a tape measure. Kit is FULLY bolt on except for the limit strap tab. Now for le pics!
COILS ARE TOO SHORT I KNOW I KNOW!!!!
Old 12-19-2012, 08:56 AM   #2
Señor member
Cr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shed
Cr250jumper's Avatar
Cr250jumper's Tacoma Gallery
Looks awesome!
Old 12-19-2012, 08:57 AM   #3
nofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shed
nofords08's Tacoma Gallery
Old 12-19-2012, 08:59 AM   #4
Banned
97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed
97yota4wd's Tacoma Gallery
Originally Posted by Cr250jumper View Post
Looks awesome!
x2!!
Old 12-19-2012, 09:17 AM   #5
Rompin Around
lembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shedlembowski is one of the sharper tools in the shed
lembowski's Avatar
lembowski's Tacoma Gallery
I was happy for about 1 minute when I got my front done, then I realized the rear needed done ASAP!!!
Old 12-19-2012, 09:18 AM   #6
Hiatt1991's Avatar
haha realized the same. lol
Old 12-19-2012, 09:21 AM   #7
Big tars, little/no bed.
NwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shedNwiTACO is one of the sharper tools in the shed
NwiTACO's Tacoma Gallery
I would weld the cambolt eliminator plate before they fold over the alignment tabs and start moving on you. Otherwise looks great!
Old 12-19-2012, 09:24 AM   #8
Goldmember
NC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shedNC15TRD is one of the sharper tools in the shed
NC15TRD's Avatar
NC15TRD's Tacoma Gallery
Might wanna post a couple pics jk Looks great!
Old 12-19-2012, 09:28 AM   #9
Hiatt1991's Avatar
Those will be undergoing extreme testing on new years to see if they need to be welded or not. We wanted the kit to be as bolt on as possible so if it isnt necessary then lets make it easier. The tabs sit totally flush so there is more contact than the stock round tabs. Ill update this thread with the results!
Old 12-19-2012, 09:29 AM   #10
Hiatt1991's Avatar
lol. Thought I should be as thorough as possible.
Old 12-19-2012, 09:34 AM   #12
Hiatt1991's Avatar
Originally Posted by EATABULLETcom View Post
What do you think they are gonna charge for this kit, and are they gonna have a kit for the 4wd guys?
Yup. They will be having a 4wd truck come in sometime early next year. I cant really speak for LSK but we are gunna try and set the price between what camburg and engage charges for thier base kits. Both dont include hiem uppers for the UCAs. They will also be doing a 2wd race kit, lift spindles and a 4wd spindle.
Old 12-19-2012, 09:40 AM   #13
RelentlessTaco's Avatar
Looks good. I started when going to college for engineering too.
Old 12-19-2012, 09:43 AM   #14
Hiatt1991's Avatar
Thanks Eric. Love your work man!
Old 12-19-2012, 09:53 AM   #15
Mr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shed
Mr Salty's Avatar
Mr Salty's Tacoma Gallery
What no powdercoat?
Wheres the Maxtrac's spindles?
Old 12-19-2012, 10:07 AM   #16
Señor member
Originally Posted by Mr Salty View Post
What no powdercoat?
I would assume they want to stress test it first because its the prototype before they powder coat. Also probably trying to make sure stock spindles will clear and work
Old 12-19-2012, 10:14 AM   #17
SoCal LED Dash Swap
Jerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shed
Jerez's Avatar
Name: Roderick aka Royer
Jerez's Tacoma Gallery
lsk does some good work and hiatts right...these guys are young but damn do they know their stuff when it comes to fab work
saw the kit in person this past weekend and looks good bud
Old 12-19-2012, 11:20 AM   #18
Hiatt1991's Avatar
This. Wanted to check for breaks and see if.it worked with stockers too.
Old 12-19-2012, 11:21 AM   #19
Just think outside the Yota
CayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shedCayucosTacoma is one of the sharper tools in the shed
CayucosTacoma's Avatar
CayucosTacoma's Tacoma Gallery
looks super awesome!
Can't wait for some videos
Old 12-19-2012, 11:21 AM   #20
Betty White Edition Heep ZJ
jonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shedjonny is one of the sharper tools in the shed
jonny's Avatar
jonny's Tacoma Gallery
congrats Hiatt!
now get some fkn tires will ya? haha
Group Buy: LSK 2nd Gen Stock Length Lower Control Arms blackhawke88 Group Buys 201 08-11-2013 08:47 AM
LSK Fabrications - Burbank, CA blackhawke88 Vendor Reviews 16 05-08-2013 07:35 PM
Hi TW from LSK LSK New Members 15 08-27-2012 03:52 PM
Anyone near Burbank to help out a possible new Tacoma owner? ckent42 Southern California 7 08-09-2012 12:22 AM
Burbank CA Tacoma Off Road Rides ratrod 2nd Gen. Tacomas 1 11-26-2010 04:07 PM
