Powder Coated Tailgate Cap System by KB Voodoo *REVIEW*
Discussion in 'Vendor Reviews' started by RearViewMirror, Sep 12, 2014.
  1. Nov 14, 2014 at 3:15 PM
    #41
    TunnelDV
    TunnelDV Well-Known Member
    Derek
    Denver
    10 4Dr Tacoma White
  2. Jul 8, 2015 at 8:14 PM
    #42
    Hiker
    Hiker Well-Known Member
    HotZona
    Any chance you'll be making these with diamond plate material, then finish them in black?. I have a black diamond plate toolbox and it would match up nicely.. Thanks
  3. Jul 8, 2015 at 8:21 PM
    #43
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Unfortunately no. I'm not a fan of diamond plate on Tacomas.
    TRDSport10 likes this.
  4. Feb 26, 2016 at 11:01 AM
    #44
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    I did buy one of these for my 09.excellent service and better than stock by far.
    KB Voodoo likes this.
  5. Mar 24, 2018 at 2:55 PM
    #45
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Purchased in 2014, did this in 2015:
    [​IMG] [​IMG] [​IMG]
    Aw9d likes this.
  6. Mar 25, 2018 at 8:57 AM
    #46
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Mine did this as well, switched back to the plastic cap until I can get it cleaned up, and repainted. Powder coat needs a very clean surface, and all edges deburred properly and ideally radiused for long paint life.
    Aw9d likes this.
  7. Mar 25, 2018 at 10:09 AM
    #47
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    DoorDing likes this.
  8. Jun 20, 2022 at 11:42 AM
    #48
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    NVM
  9. Nov 9, 2023 at 11:12 PM
    #49
    jdtoothnail
    jdtoothnail Member
    Joey
    Wapato, WA
    05 TRD Sport DC 4x4 w/ 3" Toytec Lift
    3" Toytec/Eibach Coilover lift w/ 5100s in front, Toytec rear BOSS shocks, Light Racing UCAs, OME Dakar Rear Leaf Packs w/ rear axle degree shims, Toyo Open Country A/T II LT285/75R16 (33"), Gear Alloy 712MB Injectors (Machined Black & Chrome wheels), Airaid Cool Air Intake System, TRD Exhaust, Black Head Light Mod, GrillCraft Black Mesh Upper & Lower Grill, Removed Mudflaps, Jensen VM9324 DVD player (secret e-brake override code on all Jensens) w/ Streaming Bluetooth Adapter, Steering Wheel Adapter & Rear Back-up Camera... ALL done by me, thanks to all the info here on TW. If I can do it, you can DEFINITELY do it!
    Is the price still $80 + shipping? :D Your website has it at $150 + $55 shipping.
