-   Wheeler's Off-Road (http://www.tacomaworld.com/forum/wheelers-off-road/)
-   -   Wheeler's 05+ HD Replacement Pack (http://www.tacomaworld.com/forum/wheelers-off-road/266894-wheelers-05-hd-replacement-pack.html)
YotaDan 03-06-2013 10:20 AM
This is a heavy duty rear leaf spring set for owners wanting a stouter rear spring set for their Tacoma. Great for trucks hauling extra weight, utility and expedition applications. They have 4 leafs plus an overload leaf and feature diamond cut leaf ends with anti-friction pads, bolt style pack clamps and a provision for the factory e-brake cable clamp. They are supplied with a performance polyurethane bushing set and zinc coated u-bolts. They fit Standard, Xtra and Double Cab chassis, 4cyl and V6. Depending on chassis and load, your truck will sit higher than stock. The 3rd leaf down can be removed for reduced ride height and a softer spring rate if desired. These springs are left and right specific and are made from 60mm width material. These leaf packs work well with a performance gas charged shock such as Bilstein 5100's (listed below). You will notice an improvement in the stability and ride height of your Tacoma under load as well as enhanced control of axle wrap.
Couple pics for those of you who are curious:
http://i956.photobucket.com/albums/a...ps56804f3d.jpg
http://i956.photobucket.com/albums/a...psec8998b6.jpg
Jeffsdeere 03-14-2013 12:27 PM
Are you guys running any special deals on these? What does shipping generally run?
kryten 03-14-2013 12:29 PM
x2
How about to Canada?
Would this be considered a direct (heavier duty) replacement for 2nd gen Tacoma TSB (4 leaf) springs?
splitbolt 04-30-2013 10:13 PM
Are these made by Alcan?
ToyComa92 04-30-2013 10:19 PM
Will this give me more or less lift in the rear rather then a stock leaf pack with TSB with over 100K and an 1 and a quarter inch AAL? if so how much?
splitbolt 04-30-2013 10:43 PM
Never mind. They are.
http://www.tacomaworld.com/forum/sus...ml#post5962700
08TacoTrD 03-02-2014 06:37 PM
So are these just about neutral to stock height or do they give any lift over the 3 leaf (2/1) springs?
68vert 08-24-2014 08:42 PM
anyone have any feedback on these? trying to decide between these or 3 leaf HD add-a-leaf
