Wheel Backspacing and Offset Info
* Tire Finding Tools Referenced Products Thread Tools Search this Thread
Old 10-27-2013, 05:43 PM   #501
replica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shedreplica9000 is one of the sharper tools in the shed
replica9000's Avatar
replica9000's Tacoma Gallery
Originally Posted by itzyoboipaul View Post
got a 2013 double cab taco
im currently running mb tko 17x8.5
-6mm offset
4.5 inch backspace
and i like how these are about half an inch out of the fenders
im thinking for xmas, i might get these
http://www.ebay.com/itm/Pro-Comp-Xtr...#ht_1716wt_904
pro comp 7089
17 x 9 inch
offset -6mm
backspace 4.75 inches
will it fit without any issues? will it look pretty much the same stance as the TKO mentioned above?
I'm running 18x9 rims with a 0mm offset. -6mm means it will stick out 6mm (roughly 1/4") from the fender more than my wheels do.
Old 11-12-2013, 11:43 PM   #502
Rich91710's Avatar
Rich91710's Tacoma Gallery
Found this in some old files.... handy quick reference.
Old 11-19-2013, 08:42 PM   #504
JAFO is on a distinguished road
JAFO's Tacoma Gallery
I read through a great portion of this thread. Interestingly there was no specific answer supplied making it clear on the backspace that is the proper dimension when running the 285 tires. If I missed it I apologize but seemed like a lot of debate then the people asking "if this will work" post. Clearly there has to be an optimum backspace required to allow the larger tire to fit with no mods or minimal trimming.
While I agree it is so hard to tally up all the factory dimensions of the optional wheels offered by Toyota but why worry about it quite honestly being you will change them.
As I have been searching for wheels I like, it is a chore to get the information from the manufacturer about the backspacing.
With that said, does anyone have the magic numbers for a 7" to 8" wide wheel? Is it 4.5" BS that will allow the proper clearance of the UCA while not sticking out much past the fender line?
Old 11-20-2013, 10:55 AM   #505
~~I'll just put the tip in...~~
AWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shedAWF ROWD is one of the sharper tools in the shed
AWF ROWD's Avatar
Air Force: SpecOps PJ
AWF ROWD's Tacoma Gallery
You're still gonna get a multitude of answers because most lifts are gonna have different number outcomes....4.5" seems to be where a lot of guys are at though...
Old 11-20-2013, 10:18 PM   #507
At the moment, I have a 18x9 wheel with 0 offset (so should have a 5" backspacing). The tire is 305/60-18. I also have a 3" lift with LR UCAs. I have about 1/2" between the tire and UCA, and my tire sticks out no more than 1/2" from the flare.
I should be swapping to a 16x8 with 0 offset soon, and a 285/75-16 tire (very common for us around here). That should put my tire flush with the fender flare.
Old 11-21-2013, 06:31 PM   #509
I agree. The variables are endless. Final lift kit geometry, simple leveling kits, lift total height, tires are spec'd generically, wheels etc.
Its all good. Its a good thread but doubt it will answer much.
Old 12-05-2013, 10:13 AM   #510
xTACOMAx is on a distinguished road
xTACOMAx's Tacoma Gallery
The xd spy rims come in the size 18" x8.5 with a offset of +18 and a backspacing of 5.460 how much of a difference would these rims stick out from the stock TRD sport 17" rims?
Old 12-05-2013, 04:02 PM   #511
AWF ROWD's Avatar
[QUOTE=xTACOMAx;7809836]The xd spy rims come in the size 18" x8.5 with a offset of +18 and a backspacing of 5.460 how much of a difference would these rims stick out from the stock TRD sport 17" rims?[QUOTE]
Your stockies are 7.5"
wide, with a positive offset of +30mm,,,gonna have to do some math in one the wheel spec charts on a thread on wheel specs..
Bounce around here..maybe answer some of your questions..
http://www.tacomaworld.com/forum/whe...eel-specs.html
Old 12-27-2013, 10:16 AM   #512
jefffireblaze is on a distinguished road
jefffireblaze's Tacoma Gallery
New to this site so sorry if this has already been asked.
Is anyone currently running 18x10? And if so did u have to trim or have any problems driving daily or rubbing on anything?
I want to run 18x10 on 33's with wheels that off set 24 with a 6 inch lift. I really don't want to trim it's a new taco.
Old 12-27-2013, 10:25 AM   #513
You're going to have to start cutting just for the 6" lift. You'll have to do a drop bracket kit and that requires cutting out the cross member. Unless you do a 3" suspension lift and a 3" body lift.
You mentioned 18x10 rims, and a 33" tire, but how wide of a tire? I'm currently running 18x9 -0 offset rims and 305/60 (roughly 33x12) tires with a 3" lift. I had to trim some of the inner fender flare, most of the mudflap (might as well just remove it), and chop some of the cab mount. It's not noticeable unless you're looking for it.
Old 12-27-2013, 01:35 PM   #514
Well my main question is...The back space is recommended 4.5...is anyone running with 5.0? And if so what problems do u have?
Old 12-29-2013, 05:14 PM   #515
B4nn3d
jetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant futurejetta.the.hut has a brilliant future
jetta.the.hut's Avatar
jetta.the.hut's Tacoma Gallery
I bought some 16x9 enduros with a -12 offset, backspace of 4.53. Can I roll with my 245/75/16 for now or do i need to go bigger?
Old 12-29-2013, 05:50 PM   #516
Rich91710's Avatar
Had a post a couple of days ago from a guy running 285/70-17 on 17x9 with -12 and they rub the LCA.
Old 12-30-2013, 02:02 PM   #517
B4nn3d
yeah thats why i got 16x9's im really wanting 265's . im running a 3" Old Man Emu 885's with a 1/4 poly spacer I hope i dont rub.
Old 12-30-2013, 03:43 PM   #518
AWF ROWD's Avatar
Rich, Im running that exact setup @ 3" with Dura Tracs(which seem rub more than other's, due to the pronounced shoulder lugs), but I cleared the LCA's no prob, had to ditch the flaps, and trim bottom inside corner plastic, with minor Cab Mount rub at full lock, installing LR UCA's this weekend so I can move the suspension to the front so I don't have to CMC...alls I need is a 1/2" to clear...
Old 12-30-2013, 03:49 PM   #519
AWF ROWD's Avatar
If you want to go bigger I think you can run with some 265's with no prob...the -12 offset is going to pull your tire away from your suspension.
Old 12-30-2013, 07:08 PM   #520
Supashawn is on a distinguished road
Supashawn's Tacoma Gallery
would a 16x8 with 4.25" backspacing be better or worse for rubbing?
Help with offset and backspacing Sanders17 Wheels & Tires 11 08-22-2011 04:34 PM
Offset and backspacing??? VTaco08 Wheels & Tires 1 11-06-2010 04:52 AM
Backspacing, Offset? SCFirefighter Wheels & Tires 12 07-28-2010 08:45 AM
wheel offset and backspacing bill-e-boy 1st Gen. Tacomas 7 07-20-2010 09:37 PM
Offset / Backspacing boshak 1st Gen. Tacomas 1 07-16-2010 10:23 AM
