275/70/17 (32") tires - will they fit?
Old 07-21-2010, 11:12 AM   #1
STEVECBR929RR
STEVECBR929RR is on a distinguished road
STEVECBR929RR's Tacoma Gallery
Exclamation 275/70/17 (32") tires - will they fit?
ok guys,
Anyone know if I can fit 275/70/17 (32") tires with the bilstein 5100's and nothing else without rubbing or trimming?
thanks!!
Steve
Old 07-21-2010, 11:17 AM   #2
Lets Do It!
wiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shedwiscdave is one of the sharper tools in the shed
wiscdave's Avatar
wiscdave's Tacoma Gallery
Yep, they should fit in general on the stock rims. Exactly what brand of tire are you talking about though
Old 07-21-2010, 11:20 AM   #3
STEVECBR929RR
Thumbs up
Thanks!
I sure hope so! Everyone says you will need to trim with 285/70/17 or else they will rub. And if you ask me there is no point in installin the billies if I am only going to run 265/70/17's as those will fit with the stock suspension. I figure 275/70/17 is a good middle ground...
Any other thoughts?
Old 07-21-2010, 11:31 AM   #4
sanga700 will become famous soon enoughsanga700 will become famous soon enough
sanga700's Tacoma Gallery
I ran 275/65/17 TRD stock wheel. I then have a local shop installed 275/70/17 to see if they fit but, they WON't fit because it rubbed so bad on stock UCA . Im running all 4 corners of 5100 @ 1.75 "
Old 07-21-2010, 11:32 AM   #5
Lets Do It!
wiscdave's Avatar
Do a search for your exact type of tire in that size..plenty of guys running those
Old 07-21-2010, 11:35 AM   #6
STEVECBR929RR
I wanted to buy Goodyear Duratracs but they dont make them in 275/70/17 so probably BF Goodrich...
Old 07-21-2010, 11:37 AM   #7
STEVECBR929RR
Sanga, maybe they would have fit at 2.75 instead of 1.75? no?
Old 07-21-2010, 12:07 PM   #8
with 275/70/17 I think you have to run with aftermarket wheels with big backspacing or wheel spacers with stock wheels at 1.75"
Old 07-21-2010, 12:28 PM   #9
Lets Do It!
wiscdave's Avatar
I researched the hell out of this before I just bought new rims and 285s
check out this link
http://www.tacomaworld.com/forum/whe...-they-rub.html
Old 07-21-2010, 12:58 PM   #10
STEVECBR929RR
yeah believe it or not I saw that link - still sounds like some are saying it will rub the UCAs and some are saying it wont...
Old 07-21-2010, 01:30 PM   #11
OK . Here is my advise why don't you go to your local tire shop talk to them and have them mount 2 front tires . That's the best way you could decide yourself .
Old 07-22-2010, 10:44 AM   #12
raycie has a brilliant futureraycie has a brilliant futureraycie has a brilliant futureraycie has a brilliant futureraycie has a brilliant futureraycie has a brilliant futureraycie has a brilliant futureraycie has a brilliant futureraycie has a brilliant futureraycie has a brilliant futureraycie has a brilliant future
raycie's Avatar
raycie's Tacoma Gallery
With 265/70/17 on stock suspension I was fine.. With 5100's set at 1.75 I had to trim. Yes this is 265's,, so with a larger tire you would also need to trim.
Old 07-22-2010, 12:51 PM   #13
Every truck had a bit diffirent . Im currently running 265/70.17 handkook tires with all 4 corners of 5100@1.75" without any rub at all . Also I ran 265/75.16 or 275/65/17 without any rub at all .
Old 07-22-2010, 02:23 PM   #14
raycie's Avatar
Originally Posted by sanga700 View Post
Every truck had a bit diffirent . Im currently running 265/70.17 handkook tires with all 4 corners of " without any rub at all . Also I ran 265/75.16 or 275/65/17 without any rub at all .
wow..differences.. You're telling me.. My truck can't have billies @ 1.75 in the rear.. And you have 1.75 at all 4 corners??? Wow.. J/K...
my rub was not driving, was when wheel was turned, and I went over speed bump or into driveway...
Old 07-23-2010, 09:57 PM   #15
1BADTOY is on a distinguished road
1BADTOY's Tacoma Gallery
Im running michelin 265/70/17 on mine with 5100s front set at 1.75 and tsb leaf in rear. i did get very minor rub on arms, which stopped in a couple months, and certainly never had to cut anything.
now im wanting a slightly larger tire.. maybe a 275/70/17, but will probably set the front at 2.5 and add another leaf to rear.. but dont know yet if this is possible on stock rims and if it is whether or not it will cause any problems.. will prob just get new rims..
...still researching
3" lift, 17" wheels, BFG 275/70/17 TA KO's Tacofly Suspension 16 11-27-2013 01:34 PM
Help! Bilstein 5100's in front only - can i fit 265/75/17? Or 275/70/17? Thanks!!! STEVECBR929RR Wheels & Tires 1 07-15-2010 10:12 AM
275/70/17 (32.2) or 275/65/17(31.1), can't decide a lil help to a newbie!?! Twony Wheels & Tires 6 02-04-2010 04:55 AM
275/70/17"s??? tacody Wheels & Tires 4 04-21-2009 08:55 PM
GoodYear Silent Armor 275/70/17 tires pb2themax Buy / Sell / Trade 11 02-26-2008 09:04 AM
