Nitto Terra grapplers for $128.95
Discussion in 'Wheels & Tires' started by Rucas, Aug 6, 2010.
  1. Aug 6, 2010 at 3:09 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Im tempted to get a set of these because there $560 for 4 delivered.
    But I cant figure out the load rating? It just says max load rating (single tire) 2,535lbs. whats this in terms of P and LT?
    http://www.summitracing.com/parts/NIT-200400/
  2. Aug 6, 2010 at 3:13 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    thats probably about C load range
  3. Aug 6, 2010 at 3:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    "P" is Passenger. "LT" is Light Truck. an "LT" tire is more heavey duty.
  4. Aug 6, 2010 at 3:15 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    You'll love those tires, they should suit you fine with load range, and the look pretty bad ass
  5. Aug 6, 2010 at 3:15 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    so are they "P" or "LT"?
    What is "C" rating for?
  6. Aug 6, 2010 at 3:16 PM
    Yoytoda
    Roland
    completely stock
    x2 but for these particular tires its probably an LT with a C load range. Usually a E load range is at least 3000lbs capacity
  7. Aug 6, 2010 at 3:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mine are "E" rated, and 2580 lbs. each :confused:
  8. Aug 6, 2010 at 3:31 PM
    Yoytoda
    Roland
    completely stock
    Really??? What tires are they?
    hard to read but the TGrapplers in E range are 3195#s
  9. Aug 6, 2010 at 3:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mine are the Cooper Zeon...but....Maybe they are "D" range then??? I thought I saw they said "E". Meh....I'll check later :eek:
  10. Aug 6, 2010 at 3:48 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    so im lost now. are the tires in the first post at a good rating for occasional off road?
  11. Aug 6, 2010 at 3:49 PM
    Yoytoda
    Roland
    completely stock
    yes i just wouldnt air down below 20psi over sharp rocks. Hell i wheel the chit outta my stock dunflop but i just dont air down because of weak sidewalls. The higher the rating the stronger the sidewalls
  12. Aug 6, 2010 at 4:47 PM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    Wow Chris.. if yours are E rated that must be a stiff ride. usually E rated are for Super duty trucks.
  13. Aug 6, 2010 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....I think Im thinking of the tires on the Dodge...They are E rated.
