Trimming plastic on fenders for tire fitting
Old 08-17-2010, 09:50 AM   #1
afbeetle [OP] afbeetle is offline
afbeetle is on a distinguished road
afbeetle's Tacoma Gallery
Just bought new tires...went from 265 65 17 to 265 70 17. Took off the mud flaps but it still rubs slightly in the front. Need to trim the plastic but have never done it before and I don't want it to look trashy. Anyone have pictures/tips on how to trim the plastic?? Thanks.
Old 08-17-2010, 09:53 AM   #2
Lieutenant Dan.
DeeKay21's Avatar
Firefighter: Lieutenant
DeeKay21's Tacoma Gallery
Just get a hold of a dremel and cut away.
Old 08-17-2010, 10:03 AM   #3
ilg ilg is offline
VanCity Taco.
ilg is a splendid one to beholdilg is a splendid one to beholdilg is a splendid one to beholdilg is a splendid one to beholdilg is a splendid one to beholdilg is a splendid one to beholdilg is a splendid one to beholdilg is a splendid one to behold
ilg's Avatar
ilg's Tacoma Gallery
When I went up a size in tire, they rubbed a bit.
I used a heat gun and actually heated up the lower section of the flare (see attached "before" photo), then slightly folded back the piece that was rubbing. It gave me more than enough clearance. It didn't take much as it was only rubbing a bit, mainly during turns or coming in and out of driveways.
It might work for you, but you might be rubbing a little more than I was. It's worth a shot, and if its still not enough, then you can cut at that point.
Old 08-17-2010, 10:14 AM   #4
ilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shed
ilovetacos's Avatar
ilovetacos's Tacoma Gallery
Send a message via ICQ to ilovetacos
Just use a heat gun and a new razorblade. Trim very slowly and only what is needed for the tires to not rub. I had a buddy in the truck turning the steering wheel as I cut what is needed. You also have to take in effect when the tires are articulating up and down and cut enough so they have to room to do so.
I recently upsized from 265/75-16 (32"x10.50") to 285/75-16 (33"x11.50") and had to cut more of the front flare and a small portion of the rear flare.
Front Flare
Rear Flare
Trimming Stock fenders... Oury 2nd Gen. Tacomas 12 11-07-2011 08:06 AM
Tire Fitting hanaleitaco 2nd Gen. Tacomas 4 04-26-2011 03:51 PM
New Tire/Wheel Setup - Rubbing or Trimming? blacksandtaco Wheels & Tires 6 02-08-2011 08:50 PM
Bedline spray on plastic fenders? YodaMedic 2nd Gen. Tacomas 18 08-03-2009 02:10 PM
best way to clean/protect plastic fenders? matty dread Detailing 5 06-30-2008 08:27 PM
