295/70/17? Did some minor trimming still rubbing
Old 08-24-2010, 03:27 PM   #1
Atron22 [OP] Atron22 is offline
Atron22 is on a distinguished road
Atron22's Tacoma Gallery
I am running a 295/70/17 on my 05 taco DC. I did some trimming and still rubbing. Any ideas guys? Would spacer help me?
Old 08-24-2010, 05:45 PM   #2
Discount Tire Company
Archangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shedArchangel is one of the sharper tools in the shed
Archangel's Avatar
Archangel's Tacoma Gallery
1. which wheel?
2. spacers work (spidertraxx)
Old 08-24-2010, 06:07 PM   #3
Hacksaw engineer
Trapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud of
Trapper6speed's Avatar
Trapper6speed's Tacoma Gallery
You might need just a mini 1 inch spacer. Or even a set of spydertrax. When I go to the 70 series tires I hope I have money for 5100.
Old 08-24-2010, 06:09 PM   #4
Slamry
1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed
1337Taco's Avatar
1337Taco's Tacoma Gallery
Have you chopped your cab mounts? What exactly are you rubbing on?
Old 08-24-2010, 06:10 PM   #5
ktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shed
ktmrider's Avatar
ktmrider's Tacoma Gallery
ok the only reason you should need spacers if you are rubbing on the upper control arm, where are you rubbing it will help us narrow this down.
Old 08-24-2010, 06:16 PM   #6
BANNED in 49 states...
AriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shedAriZonaD54 is one of the sharper tools in the shed
AriZonaD54's Avatar
AriZonaD54's Tacoma Gallery
This and then chop the living daylights out of the inner fender trim.
Old 08-24-2010, 06:18 PM   #7
Slamry
1337Taco's Avatar
Haha, mine is just ripped out completely.
Old 08-24-2010, 06:19 PM   #8
AriZonaD54's Avatar
My man! Da shit!
Old 08-24-2010, 06:20 PM   #9
Slamry
1337Taco's Avatar
Soooo, e39? When is it going in? Or where you kidding?
Old 08-25-2010, 02:23 AM   #10
SpaceGoat is on a distinguished road
SpaceGoat's Tacoma Gallery
I'm running 285/70/17 ProComp xTremes and rubbed on the cab mounts, but just a quick trim and box in...all good. Have wheel lock to wheel lock...with almost no inner fenders but im only running 5100s at 2.5 up front, nothing else.
Old 08-25-2010, 07:03 AM   #11
I am rubbing on the inner fender, on metal, I guess that would be the cab mount. How would I go about trimming that?
Old 08-25-2010, 07:06 AM   #12
Where are the cab mounts located? Is this hard to do? What do I need as far as tools?
Old 08-26-2010, 03:57 AM   #13
Cab mounts are located closest to your cab...if you are looking at the drivers side front wheel, on your right. As for tools, saw's all i've been told it can be done but I took mine to my favorite 4x4 shop. He used plasma cutter then welded up a plate to "box" in the hole that was cut out, then painted over it all with undercoating. all for 100 bucks. YMMV.
Anyone running 295/70/17 or 305/70/17's ? RedTaco2134 Wheels & Tires 10 12-13-2013 12:57 PM
295 70 17 with 3" spacer lift? TRDBandit 2nd Gen. Tacomas 7 06-26-2011 10:50 PM
295/70/18 or 295/70/17 FXHO 2nd Gen. Tacomas 3 11-21-2010 09:46 PM
tires in 295/70/17? ETaco23 Wheels & Tires 5 10-31-2009 09:55 PM
285/70-17's vs. 305/65-17's ... rubbing and trimming ... Randy1 Wheels & Tires 3 05-22-2009 01:18 PM
