tire size ?
Old 09-08-2010, 03:00 PM   #1
lynyrd3 [OP] lynyrd3 is offline
HARDCORE CARNIVORE BOW HUNTER
lynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shedlynyrd3 is one of the sharper tools in the shed
lynyrd3's Avatar
lynyrd3's Tacoma Gallery
Send a message via Yahoo to lynyrd3
Question tire size ?
I have an 08 (non TRD ) 4wd, access cab, Tire size now is 245/75R16 on the stock 6 lug steel wheels. Had the suspension TSB done . Going to get the bilsteins for the front because it sits high in rear end now ,but much better ride . My Question is ,what are the largest tires I can put on these stock rims now that I have all this clearance now ? Thanks
Old 09-08-2010, 03:03 PM   #2
The Man!
JLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shed
JLee's Avatar
JLee's Tacoma Gallery
I think 275/85R16's but I could be wrong.
Old 09-08-2010, 03:04 PM   #3
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
265/75/16 without wheel spacers.
285/75/16 with less backspacing and some trimming.
Old 09-08-2010, 03:04 PM   #4
Yota Doc
DocBrown86 is a name known to allDocBrown86 is a name known to allDocBrown86 is a name known to allDocBrown86 is a name known to allDocBrown86 is a name known to allDocBrown86 is a name known to all
DocBrown86's Avatar
DocBrown86's Tacoma Gallery
[QUOTE=lynyrd3;2151312]I have an 08 (non TRD ) 4wd, access cab, Tire size now is 245/75R16 on the stock 6 lug steel wheels. Had the suspension TSB done . Going to get the bilsteins for the front because it sits high in rear end now ,but much better ride . My Question is ,what are the largest tires I can put on these stock rims now that I have all this clearance now ? Thanks[/QUOTE
Id try 265/75/16's. Ive got a similar setup on my 04.
Old 09-08-2010, 03:05 PM   #5
The Man!
JLee's Avatar
Really? 265/75R16's I have 265/70R16's on my 02 and I have lots of room.
Old 09-08-2010, 03:06 PM   #6
Yota Doc
DocBrown86's Avatar
265/70/16 is stock...
Old 09-08-2010, 03:06 PM   #7
braaap
steve o 77's Avatar
yeah, but the 285's will hit the UCA's without wheel spacers. There is plenty of room in the fender wells though.
If he gets spacers or some wheels with less backspacing he could run 285's.
Old 09-08-2010, 03:08 PM   #8
The Man!
JLee's Avatar
I see you would think the 2 gen's could fit a larger tire then the first gen's stock but I guess not.
Old 09-08-2010, 03:52 PM   #10
The Man!
JLee's Avatar
Thanks guys ! Will 265/75R16 fit on my stock 6 lug steel rims ?
You should be good with that. I say get after market wheels or a spacer so you can get some 285's I personally think it looks so much better with a wider tire.
Old 09-08-2010, 03:55 PM   #11
David K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shed
David K's Avatar
David K's Tacoma Gallery
You have room with the tires pointing straight... but, when you are turning... and hit a bump... how much room do you have then? 265/75-16 is a 1" larger diameter tire than stock (for the OR TRDs).
Old 09-08-2010, 03:58 PM   #12
Yota Doc
DocBrown86's Avatar
265/75/16 may rub, but very slightly
Old 09-08-2010, 04:19 PM   #13
lynyrd3's Avatar
Do not forget I had the suspension TSB done, that really jacked the rear end up,and if I set the bilsteins at 2.5 maybe it will give me the room for the 265/75R16s ???? THANKS AGAIN. Gonna paint the stock rims black at some point when I get new tires.Still the original factory 245/75R16 Dunlop tires. Almost 30000K.Really do not want to get too crazy,mostly stay on the blacktop !
Old 09-08-2010, 04:33 PM   #15
The Man!
JLee's Avatar
OH yeah .....what do you think about KUMHO Tires Road Venture SAT KL61 or AT KL 78 ??
I just checked them out in Tire rack they look fine for street use and light off road. But for that price i would look into the DuraTracks http://www.tirerack.com/tires/tires....omCompare1=yes there not much more and I have read nothing but good things about this tire. And seeing how your in NY they will do you good in the winter.
Old 09-09-2010, 11:04 AM   #16
Yota Doc
DocBrown86's Avatar
Workin on a customers 07 taco w/ 285/75/16. He's got a 38mm wheel spacer on stock alloys, and a 2 inch spacer lift. Lots of room between the UCA and sidewall, but tire rubs on sharp turns.
Old 09-09-2010, 01:32 PM   #17
Shinty Killer
Gabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shedGabex35 is one of the sharper tools in the shed
Marines:
Gabex35's Tacoma Gallery
How bad is the rubbing(at full turn)? and what is it that rubs?
I'm looking at doing something similar. Thanks
Old 09-09-2010, 08:54 PM   #18
Yota Doc
DocBrown86's Avatar
The corner of the tread rubs the frame
Old 09-10-2010, 10:59 AM   #19
Yota Doc
DocBrown86's Avatar
Looked at it again today, it also rubs on the flares
Old 09-10-2010, 11:10 AM   #20
Yota Doc
DocBrown86's Avatar
Another taco with 285/75/16 is in the shop (this ones a tacoworld member) stock alloys. No wheel spacers
Tire Size Help!!! jerretxx Wheels & Tires 8 04-12-2011 02:09 PM
Tire tread a factor in tire size? nvdeserted Wheels & Tires 19 10-24-2010 07:59 PM
I need help with tire size n rim size anyone? maui808 New Members 3 09-07-2010 06:49 PM
Stoopid Noobs Question, Part 5: Calculating Tire Size from Rim Size 283 Wheels & Tires 5 01-24-2009 05:11 PM
