3" Lift Tire/Wheel lift options.
Discussion in 'Wheels & Tires' started by dman597, Sep 21, 2010.
  1. Sep 21, 2010 at 8:32 AM
    dman597
    dman597 [OP] Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    As always, I searched but can't find the answer I am looking for!!!
    There are to many threads and they are all conflicting!
    I have decided to buy the 3" ready lift kit. I know a spacer lift OMG WTF BLAH BLAH BLAH. The only Off-Roading I do is on the beach and that does not count. I have a real tight budget that is why I am going with the spacer lift so PLEASE no comments of my lift choice!
    I am looking for a black / machined rims with an AT tire. Can anyone tell me what size tire I can fit that won't require trimming or very very minor trimming? Also what backspacing do I need?
  2. Sep 21, 2010 at 8:45 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    If avoiding trimming is your prime consideration, I'd probably go 265/75R16 or 265/70R17, which is the same width, but one inch taller than the factory tires.
    You might even keep your front mudflaps at that size.
    If you want a little larger, lose the front mudflaps, and are willing to consider *maybe* doing a little trimming if necessary, try 275/70R17.
    285/75R16 is pretty much guaranteed to get out the knife for heavy plastic cutting, and then a body-mount chop and pinch weld hammer if you wheel it.
  3. Sep 21, 2010 at 8:47 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Backspacing is 4.5 for an 8" wide rim, 4.75 for a 9" rim, but I'd recommend keeping it to an 8" wide rim if you're going with the tire size I recommended above.
  4. Sep 21, 2010 at 8:55 AM
    dman597
    Doug
    maryland
    I am looking for a little bigger tire a wider stance. The truck as it sits, is not proportionate IMO.
    I would like it to sit like this:
    or
  5. Sep 21, 2010 at 8:58 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    The more you're willing to cut, the bigger the tire you can run.
    Conversely, you can run a huge tire if you never turn, or go over bumps.
  6. Sep 21, 2010 at 9:00 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
  7. Sep 21, 2010 at 9:05 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
  8. Sep 21, 2010 at 9:23 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Maybe. The OP said he wants a tire with NO trimming or VERY MINOR trimming. No prob - lots of folks are reluctant to take a knife to their shiny new truck.
    But, every tire/rim combination is a little different, and every lift sits a little different.
    So if you want to avoid trimming, you have to play it safe on the size. How many threads have you seen where someone ran a 285/75R16 and had to cut back way more than they expected, or damaged their fenders while wheeling?
    Which one is you:
    "I don't want to cut my truck - I'm playing it safe" then go: 265/75R16.
    "I have a look/stance in mind, and I'm willing to either cut whatever it takes until the tires fit, or take the tires off and mount a smaller tire if/when they rub too much" then go: 285/75R16.
    Middle ground: try 275/70R17.
    No guarantees. Every tire & wheel is different. Every lift is a little different too. And taco owners vary wildly in their ability to notice/tolerate "a little bit" of rubbing.
    That's why search returns such widely varying results. Pay your money, take your chances. No whining.
  9. Sep 21, 2010 at 9:28 AM
    dman597
    Doug
    maryland
    Thanks for the info!
    I would not mind triming the inner wheel well but i am not a fan of trimming any body parts!!!
  10. Sep 21, 2010 at 9:35 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I really like the 285 width. I also have the spidertrax spacers. I bought them in preparation for the tire switch. To the OP: consider adding the spacers. It will help mitigate the extent of the trimming needed.
    I have 17" rims, and am not sure what I'll get when the time comes. 70% or 75%.
    I'm trying to arrange for a test fitting of same sized tires they have in stock. Maybe you can ask a friendly shop if they'd do that for you.
  11. Sep 21, 2010 at 9:46 AM
    dman597
    Doug
    maryland
    I am going to buy a rims too. so instead of spacers can't i get a differnt backspacing?
    what i am looking for is the bigest tire wheel combo I can fit with a 3" lift with out major trimming.
  12. Sep 21, 2010 at 10:28 AM
    SCFirefighter
    Stephan
    Cary, NC
    Yes, you can get rims that will help you avoid trimming. Good luck :)
  13. Sep 21, 2010 at 11:00 AM
    NetMonkey
    Geogetown, TX
    if you want to go with 285's, i would recommend going with 285/75/16 on 16x8 rims with 4.5 offest. this will keep the wheel\tire tucked a bit more in the fender and will make less of a rotational distance when turning and therefore cause less rubbing.
    you will need to do some minor trimming on the inner plastic fender well, but its no big deal. if you are not doing any serious off roading then you could get away without having to chop the body mount.
  14. Sep 21, 2010 at 11:14 AM
    SCFirefighter
    Stephan
    Cary, NC
    Any suggestions on how much height could I get away with on the stock 17" rims using Spidertrax? 285/70 or 285/75?
    Love you avatar by the way :)
  15. Sep 21, 2010 at 11:39 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    285/75R17 would be a *huge* 34" tire - and a quick search couldn't even find that such a tire exists.
    At the 17" rim size for a 285 width, you'd want 285/70R17.
    If you *really* want to push the envelope, you could try 295/70R17 (Nitto Terra Grappler in that size) or 305/70R17
  16. Sep 21, 2010 at 11:52 AM
    NetMonkey
    Geogetown, TX
    are the wheel spacers 1" thick? with the stock 17x7 rims (3.5 backspace), i think the total "backspace" would be equivalent to 4.5" (someone correct me if i am wrong).
    285/70/17 should be the max for you. like someone said, i dont even think they make a 285/75/17
  17. Sep 21, 2010 at 12:40 PM
    SCFirefighter
    Stephan
    Cary, NC
    That would make it easy :) Yeah, the adapters are 1.25" thick.
    Thanks.
  18. Sep 21, 2010 at 2:14 PM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
