can i powdercoat the bolts on my wheels
Discussion in 'Wheels & Tires' started by ThisGuy, Sep 27, 2010.
  1. Sep 27, 2010 at 7:35 AM
    ThisGuy
    ThisGuy [OP] Well-Known Member
    Brad
    litchfield park, az
    All Black 2010 4x4 DC TRD Sport
    3" lift, PC wheels, 33" Cooper SST. Volant intake w/ scoop, Gibson exhaust, black tails & 3rd, grillcraft black mesh....more to come
    I have ProComp 7005 wheels and the bolts are polished. I want to get them powdercoated black but does anyone know if the powdercoat will affect the thread, therefore not allowing me to screw them back in???
  2. Sep 27, 2010 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    if the threads are powdercoated, Yes. They wont thread back onto the studs correctly, unless you run a tap thru them.
  3. Sep 27, 2010 at 7:38 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    just buy black lug nuts:D
  4. Sep 27, 2010 at 7:39 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It might make the threads tight and the nuts will probably scrape off the paint so paying for powder coat to me is a waste. Once the lug nuts are on, you're better off using a rubber cap over the bolt ends or painting them using rustoleum. You'll have to fight a little to get the nuts off and repaint if you take the rims off though.
  5. Sep 27, 2010 at 8:30 AM
    ThisGuy
    Brad
    litchfield park, az
    i have black lug nuts already....im talking about the million little bolts around the edge. Do they sell those in black???
    sorry i guess i should have clarified more
  6. Sep 27, 2010 at 8:34 AM
    Pugga
    Massachusetts
    We know... most of the responses were directed towards painting the bolts.
    If you mean the bolts at the perimeter of the wheel, just powdercoat the heads and don't mess with the threads.
  7. Sep 27, 2010 at 8:37 AM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    I would get black zinc. The cleaning process will strip any coating already on them and it will hold up over time.
  8. Sep 27, 2010 at 8:43 AM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    do those even come out? I have the same wheels and wanted to paint them as well at first, but the look has kind of grown on me
  9. Sep 27, 2010 at 8:52 AM
    ThisGuy
    Brad
    litchfield park, az
    yeah i took one out yesterday. they come out really easy but i dont ever plan on using beadlocks so theyre pointless to me.
  10. Sep 27, 2010 at 1:11 PM
    BWro
    BWro Well-Known Member
    Those wheels are simulated beadlocks, not the real thing.
    I wouldnt waste the money on coating just the bolts, unless you were planning on doing the entire wheel. Just paint them
  11. Sep 27, 2010 at 4:32 PM
    Larry
    Larry CARL
    CARL
    matching paint and a small brush.
    or...take them out and stick them through holes in cardboard...spray the bolt heads...replace and repeat.
