will remounting tires help with balance issues?
Old 10-19-2010, 09:10 AM   #1
MTgirl [OP] MTgirl is offline
too many frogs, not enough princes...
MTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shedMTgirl is one of the sharper tools in the shed
MTgirl's Avatar
Gender: Chick
MTgirl's Tacoma Gallery
Before taking my truck into the tire shop for the third time in less than two weeks...1st to get the new tires, 2nd to have them rebalanced, and the upcoming 3rd visit for another balance issue...I thought I would consult TW for more information.
I had my tires put on less than 2 weeks ago. The shop failed to balance them correctly the 1st time and I was back in the shop the next day. All was good after that visit but I have an excessive amount (IMO) of weights on two of the tires. I was out this last weekend and when I got back on the highway after being on dirt roads all day I noticed that the vibes were back. Pretty sure I threw a weight off of one of the rims at some point during the day. My question is this...will remounting the tires (and repositioning them by 90 or 180 degrees) help with balancing them and require fewer weights?
I'm tired of visiting the tire shop on a weekly basis and I'm sure they're sick of me too! Oh, and I have stock rims with 31X10.5R15 Duratracs.
Old 10-19-2010, 09:14 AM   #2
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
Tire position on the vehicle does not affect wheel/tire balancing. I have a ton of weights on my wheels also I'm guessing because of the TPMS sensors. If you threw a weight, only way to fix it is to replace the weight unfortunately.
Old 10-19-2010, 09:16 AM   #3
( ͡° ͜ʖ ͡°)
Jester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shedJester243 is one of the sharper tools in the shed
Jester243's Avatar
Jester243's Tacoma Gallery
Sometimes rotating the tire 180 on the rim can help. There is sometimes a heavy spot on the tire and one on the rim that line up during mounting.
Old 10-19-2010, 09:19 AM   #4
MTgirl's Avatar
Gender: Chick
I don't mean position on the vehicle - front, rear, etc - I mean take the tire off of the rim and put it back on the same rim but just spun around clockwise or counter clockwise.
And I have a 1st gen, no TPMS!
Old 10-19-2010, 09:21 AM   #5
Wild Ginger
BrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shedBrettBretterson is one of the sharper tools in the shed
BrettBretterson's Avatar
BrettBretterson's Tacoma Gallery
She's not talking about moving the wheels around on the vehicle, she's talking about repositioning the tires on the wheels. And the answer is yes, repositioning the tires CAN help with balancing. It's called road force balancing.
One question is, after you were in the dirt, was there a lot of dirt buildup on the wheels? If yes, that will effect balancing. If not, then you did most likely lose a weight and need another rebalance. You might want to ask them to road force at least the couple wheels with excessive weights.
Old 10-19-2010, 09:22 AM   #6
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
I think it could be the rims. Mine 98 had several weights on two of the rims (same rims as yours) and I ran BFG ATs.
Old 10-19-2010, 09:24 AM   #7
vinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shedvinnyvavoom is one of the sharper tools in the shed
vinnyvavoom's Tacoma Gallery
Another option is to find a shop that with a roadforce balancing machine. I have had issues with tires and this has ALWAYS fixed it. One consideration is that all wheels do not fit on this machine and I have never owned 31's.
Old 10-19-2010, 09:27 AM   #8
MTgirl's Avatar
Gender: Chick
Dirt buildup? No. Rocks? Yes, but they came out very quickly. The vibes were pretty consistent on the 30+ mile drive home on the highway. I was throwing rocks all day and can't tell the difference between a rock and a weight being flung around but pretty sure one came off at some point.
So if it is the rims then most likely nothing can be done?
Old 10-19-2010, 09:29 AM   #9
The Man!
JLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shed
JLee's Avatar
JLee's Tacoma Gallery
Shit i just ordered wheels and tires from Tire Rack they do road force balancing and I had major vibes I took the truck to Les Schwab and the backs needed over 13oz now my truck runs down the road as it should.
Old 10-19-2010, 09:29 AM   #10
Roll Tide
HondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shed
HondaGM's Avatar
HondaGM's Tacoma Gallery
have you ran over any bears lately?
Old 10-19-2010, 09:31 AM   #11
MTgirl's Avatar
Gender: Chick
Originally Posted by Oswego View Post
Goodyear Duratracs can come with flat spots from the manufacturer - if this is the case they should be returned as defective as they will never balance properly. This can happen with all tires, but it seems the Duratracs have a higher rate of return. This is all knowledge from reading about them - I have not experienced any of this first hand.
I suggest you PM David Tarantino and ask him. He is a pro and mounted mine perfectly.
never heard of that in my pre-purchase research. how do you tell if there are flat spots? any way to test for that at the shop?
Old 10-19-2010, 09:37 AM   #12
Jlee, no sweat, if they needed 13oz, then so be it. the roadforce machines do not change the weight needed to balance a tire, they just analyze a tire at 40MPH with force applied as if you were driving. Other machines spin the tire without applying a force to the tread. This will work in most instances, but for stubborn balancing, roadforce has proved itself to me 3 times. PS- tirerack has a list of service centers with pricing in your area and they list the machine used to balance your tires.
Old 10-19-2010, 09:37 AM   #13
Wild Ginger
If the vibes just started with new tires, it's not your wheels. Unless the tire is out of round(basically defective and will never balance correctly), road force balancing will almost guarantee to fix it.
Old 10-19-2010, 09:43 AM   #14
Wild Ginger
Road force balancing can definitely change weight needed to balance a tire. Every wheel and every tire has a heavy spot, and lots of weight usually means that the heavy spots are too close together(meaning one very heavy spot), which is why so much weight is needed to counter-balance the heavy spot.
Road forcing doesn't just analyze the tire, it also determines where the heavy spots are on each and tells the tire tech exactly where to position the tire on the wheel, usually resulting in less weight need to counter balance the heavy spot.
Old 10-19-2010, 09:48 AM   #15
Pugga's Avatar
My bad, I thought you were talking about rotating the wheel on the hub, not the tire on the rim. That may help you with the excessive amount of weights but the others on here are correct, certain tires are a PITA to balance, some impossible due to defects.
Old 10-19-2010, 09:49 AM   #16
MTgirl's Avatar
Gender: Chick
never had a problem before. this is only the second set of tires that I've had on the truck.
PM sent to David
Thanks Boyd!
that's sort of what I was thinking, not everything is going to be perfectly symmetrical so it seems like a reasonable cause to me.
looking into road force now. not sure what my shop has...i shall call and disguise my voice so as to not make them suspicious.
Old 10-19-2010, 09:59 AM   #17
The Man!
JLee's Avatar
Yeah it's taken care of now and Tire Rack is paying for the Balance. I do have stubborn tires to balance 33"x12.5x15" DuraTracks mounted on 15"x10's with a 3.74" backspacing and -44mm offset so there's a lot of rim on the outside of the wheel. Here's a shot of the wheels and tires.
Old 10-19-2010, 10:30 AM   #18
MTgirl's Avatar
Gender: Chick
just use your Stanley voice
Really? You think that will be the most effective and convincing? I was thinking more along the lines of my phone sex operator voice.
I'm off to make some calls and see what they have to say...
Old 10-19-2010, 10:32 AM   #19
:POOPCORN:
98tacoma27's Avatar
Marines:
Old 10-19-2010, 10:45 AM   #20
David Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shedDavid Tarantino is one of the sharper tools in the shed
David Tarantino's Avatar
David Tarantino's Tacoma Gallery
You have to add 13oz to get them to balance...lol. Sucks for the guy above. PM David - I am not well versed in this. Tell him I sent you or better yet Ill PM him and ask him to help you.
13oz of weight is a lot theres no that tire is being balanced correctly
or theres something wrong with the wheel is it bent
Or theres something wrong with the guy doing the balance
if this guy put 13oz of weights on your tires/wheels somethings wrong
that should never have left the shop like that
Lisa all can say is find a new shop
I would like to see a pic of that wheel with 13oz on them
Can Anyone Balance Tiress Correctly or Even Do Roadforce On All Terrain Tires? TacomaGus 1st Gen. Tacomas 39 10-27-2012 07:53 AM
Anybody balance your own tires? saugus Technical Chat 2 10-01-2011 11:44 AM
Mount and balance own tires and wheels? sargo Wheels & Tires 6 09-24-2011 09:23 AM
Tacoma Specific: Tire balance issues 45longcolt 2nd Gen. Tacomas 21 04-19-2011 08:04 PM
RANT - Mount/Sipe/Balance 4 tires - HOW MUCH?!? tmd 2nd Gen. Tacomas 3 01-20-2009 04:44 PM
