295/75/16 questions
Old 10-30-2010, 11:18 PM   #1
tacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shedtacosupreme54 is one of the sharper tools in the shed
tacosupreme54's Avatar
tacosupreme54's Tacoma Gallery
295/75/16 questions
i was just wondering if many people on here has 295's, if so, i have a few questions. i will be getting new tires sometime and have been really going back and forth between the 285's and 305's. but here recently i noticed the 295 and it seems like a good size. the 305's are basically a true 33x12.5, so that's a little too wide. the 285's are like 32.8x 11.25 and that's not much bigger than a 265/75. but the 295's actually range from 33.4 to around 34 and about 11.6 wide. one reason i want to lean away from the 305's or true 33s is because i don't want to chop the cab mount. but these 295's are an inch more narrow and a tad taller, so would that eliminate my rubbing there? also, i know some guys on here even chop the cab mount with 285's. but is that for more serious off roading to allow for flexing or is it for any use? because this truck is going to stay on pavement a pretty good bit until it's paid off. used strictly on the road, will these be an issue with the cab mounts? also, i have 2.5 in the front and 2 in the rear, plus 4.5 backspacing wheels. i realize that i will i have to cut out some plastic in the fenders and that's fine, i just don't want to get into anything more intense than that, lol.
also anybody that considered or has 295's, why did you or did you not get them? are there any pros or cons with these compared to 285s and 305s? if its more trouble than it's worth to make these work, please let me know. if this is no trouble to make work without getting into the cab mount, please let me know. also, this is somewhat of an odd size and there are few brands to chose from. does anyone know a brand that makes this size to suggest? the only ones i've seen are hankook, general grabber, bf goodrich, and a couple others. i want more of an at or mt aggressive tire. i know it's asking a lot, but there is not much info on this size tire, nor many people that have them. so anybody with these or info on these, please help me out because i don't want to try to do things on my own and get myself in a mess.
thanks guys
Old 10-30-2010, 11:20 PM   #2
Slamry
1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed
1337Taco's Avatar
1337Taco's Tacoma Gallery
stroM- has 295/75/16's and had to chop his cab mount.
Old 10-30-2010, 11:23 PM   #3
do you know if he did that to allow for some serious off roading? or if it's gonna have to be done no matter what?
Old 10-30-2010, 11:26 PM   #4
Slamry
1337Taco's Avatar
He had a lot of rubbing while turning in reverse. It was also done to allow for more clearance offroading and he has an aftermarket front bumper so I'm not sure how much cutting or trimming you will have to do in front of the tire.
Old 10-31-2010, 07:29 PM   #5
alright, thanks man. i'll just try to get in touch with him.
Old 10-31-2010, 07:32 PM   #6
ktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shed
ktmrider's Avatar
ktmrider's Tacoma Gallery
I think i have a idea what constitutes getting the cab chop, with stock UCAs I never rubbed the cab mount, but when I got UCAs and the right specs, I can no longer make U turns. I have 285s BTW
Old 10-31-2010, 07:36 PM   #7
so the new ucas and larger tires limited how far you can turn?
Old 10-31-2010, 07:37 PM   #8
ktmrider's Avatar
not it just is eating my tire on the cab mount cause my caster is too low on the left side
Old 10-31-2010, 07:39 PM   #9
oh, ok. so at about how far of a turn does it start to rub bad? less than a full 90 degree turn?
Old 10-31-2010, 07:40 PM   #10
ktmrider's Avatar
if you are going straight 1 and 3/4 turns to the left.
Old 10-31-2010, 08:09 PM   #12
ktmrider's Avatar
thats with a good 10k on the tires too, it would be worse if they were brand new
Old 10-31-2010, 09:23 PM   #13
ok, i'm looking at hankook dynapro mt's. the actuall size of the 285/75/16 is 33x11.6 and the 295/75/16 is 33.6x 11.6. so is .6 of an inch going to make a ton of difference?
Old 06-28-2011, 09:14 PM   #14
Well I finally got around to getting these and having them put on. I had to drive a little careful on the way home to not rip my fenders and bumper off. But I got home, checked everything and cut back a few hunks of plastic on the inner rear fender and on the front fender/bumper. I had no trouble with the cab mount. I am clear lock to lock; even with the tires at the angle closest to the cab mount I have about 3/8-1/2'' clearance. I even tested my trimming on a small trail and had no rubbing. So as of now, no cab mount chop needed on my 295/75/16's (33.6'' x 11.6'').
(yes, repost from another thread i had, but just passing on info for anyone that may reference this thread)
Old 06-28-2011, 09:16 PM   #15
Super Mod!
BlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shed
BlueTaco07's Avatar
BlueTaco07's Tacoma Gallery
I would talk to Blacktacoma23 hes got em
Old 06-28-2011, 09:19 PM   #16
lol, I just posted to show that I had got them put on today and didn't need a cab mount chop
Old 06-28-2011, 09:21 PM   #17
Super Mod!
BlueTaco07's Avatar
Ohh didnt see that. What size lift are you running?
Old 06-28-2011, 09:27 PM   #19
Super Mod!
BlueTaco07's Avatar
3" OME
You think once I get my procomp 3, I could clear the same size tire?
295/75/16 on TRD wheels? sfcadams Wheels & Tires 11 02-03-2012 12:05 AM
WTB: 285/75/16 or 295/75/16 or... OCTaco Buy / Sell / Trade 0 09-14-2011 07:14 PM
Anyone have285/75/16 or 295/75/16 on TRD stock rims esimmons Wheels & Tires 8 07-21-2011 09:09 PM
FS: Hankook Dynapro MT's 295/75/16 stroM- Buy / Sell / Trade 24 08-03-2010 09:52 AM
295/75/16 Tires Alaskaflyer Wheels & Tires 8 02-09-2009 09:30 PM
