235/75/16 with no lift on a 5-lug..possible ?
Discussion in 'Wheels & Tires' started by BluTaco08, Oct 31, 2010.
  1. Oct 31, 2010 at 1:43 PM
    BluTaco08
    BluTaco08 [OP] I LiKe TaCos
    Hey guys. In the next 2k-3k miles I'll be in need of some new tires. Right now I'm running the Hankook ATM-RF10's in a 225/75/16 on a Helo 16x7.5'' wheel (awesome tires btw) and I'd like to go up to a 235/75/16. Two questions: Will a 235 fit on a 7.5'' width wheel and will it fit with no lift ? The 225's fit fine with no rubbing issues, but I'm worried about the 235 rubbing. Any suggestions would be greatly appreciated.
    Any pics of reg. cab's running 235's with no lift ?
    FWIW: I'm driving on '08 reg. cab, 5-lug. Thanks.
  2. Oct 31, 2010 at 1:53 PM
    Dennis3553
    Dennis3553 Well-Known Member
    Dennis
    Buffalo Ny
  3. Oct 31, 2010 at 2:34 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    235/75/15 will fit no problem...not sure if the additional 1" for the inner diameter would cause it to rub or not. I don't think there should be any problems running that size though, since the width is the same.
  4. Oct 31, 2010 at 3:09 PM
    Archangel
    Archangel Insurance Agent
    Charlotte, NC
    '13 IS250
    I would try to run a 235/70/16. It's wider and taller, but not by much. 235/70/16 is also a little more common than 235/75/16. Hope this helps, PM me with any questions that you may have. I would be more than happy to help you out.
  5. Jan 18, 2015 at 10:13 AM
    ferdie
    ferdie Member
    escondido
    05 tacoma
    if i do the black box mod will a255x70x16 fit without a lift
